Tire sizes
Old May 2, 2017 | 01:37 PM
tinsnips's Avatar
tinsnips
Default Tire sizes
What's the difference between an 85 a 90 and a 150. I want to stuff the biggest one I can on the rear of my 08 ultra
Old May 2, 2017 | 02:19 PM
mkguitar's Avatar
mkguitar
you can go wider if you use spacers, a custom wheel and/or convert to chain drive.
The aftermarket has all kinds of "wide tire" kits
I think a bike with front & rear tires about the same size handles better though
Mike
Old May 2, 2017 | 02:36 PM
rkoivisto's Avatar
rkoivisto
Default tire size
That's kind of a vague question. The width is listed in millimeters. A higher number is wider (more millimeters of width).
A stock 08 isn't going to take a very wide tire because your rear wheel is only 3 inches wide. You missed it by a year. 2009 is 5 inch wide wheel.
Old May 2, 2017 | 02:56 PM
RevBlk's Avatar
RevBlk
You can fit a 160 on your stock rim but it isn't easy if you do them by hand like I do. There is no interference with the belt guard or anything else. The tire does not like that narrow a rim. A 150 fits easy and mounts much easier.
Old May 2, 2017 | 03:42 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Example: 185/60-16
185 is the width in millimeters (divide by 25.4 to get inches - which, in this case, would be 185/25.4=7.28 inches)
60 is the aspect ratio. This is a percentage of the width and it tells you how tall the sidewall of the tire is. (185 x 60% = 111 millimeters [or 4.37 inches])
16 is the rim diameter.
Old May 2, 2017 | 04:11 PM
tinsnips's Avatar
tinsnips
Thank you. I will stick with the 150. Appreciate all the input
Moaath Khaled
Jul 21, 2019 10:08 AM
crusader1xxx
Sep 12, 2018 07:11 PM
Yukon42
Jul 23, 2017 04:30 PM
Bay225
Mar 3, 2010 06:23 PM
Dino3981
Dec 9, 2005 09:36 AM
