Warped rocker box base
Old May 6, 2017 | 07:17 PM
predatornut's Avatar
predatornut
Default Warped rocker box base
I pulled the rocker box off the rear cylinder of my 04 ultra to fix a oil leak. Following some advice I received on here I used some 400 grit wet/dry sandpaper on a piece of glass to knock down any high spots. After quite a while of working at it I have worn through the chrome on two opposite corners, the front right and rear left. It is warped, it does not sit flat on the glass regardless of how I set it.
My question is; would there be a problem with working it until I have leveled it or should I just get a different one? I have done some quick googling and mostly found them on eBay which makes me nervous that I would end up with something no better than what I have. I did find some new, but they are not factory an I wonder how well they would match the front.
Thanks for any help
Nick
Old May 6, 2017 | 07:51 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Post this up in the engine mechanical section of the tech forum..
You'll prolly get more help
Old May 6, 2017 | 08:44 PM
whocares's Avatar
whocares
Buy a new one,there not that pricey.
Old May 6, 2017 | 11:17 PM
Veekness's Avatar
Veekness
Agreed. Only $75. But at the same time, it might straighten out under torque. The rear jug gets pretty hot, which would explain the warp.
​​​​​​​Were it me, I would replace as long as it's apart. AND I would install Rockouts.
Old May 7, 2017 | 05:07 PM
predatornut
Ordered a new one from the dealer. Thanks for the help.
Nick
MxNut
Jun 22, 2019 09:35 PM
Steevo12683
Engine Mechanical Topics
Aug 4, 2017 07:23 PM
predatornut
May 7, 2017 05:03 PM
emperor wurm
May 28, 2012 07:23 AM
2006FLST
EVO
14
Apr 5, 2011 12:11 PM
