Question on riding and gearing.
Old May 21, 2017 | 10:15 PM
grubsie's Avatar
grubsie
Default Question on riding and gearing.
Recently bought my first HD and first V-twin. I have ridden metrics af all sizes all my life except for metric v-twins. Typically inline 2's, 4's or v4's.
Naturally, I understand that v-twins are a different riding style but still have a few questions.
I love the ride my 1997 Road King gives me for the most part but I am finding that scenarios like traveling at 50 mph in 4th gear is pretty smooth, but if I click it into 5th gear at that speed, I get a lot of vibration. The windshield, mirrors etc vibrate pretty bad. Even my vision is vibrated so I go back to 4th gear to minimize it.
Do v-twin riders usually ride the bike in 4th gear instead of 5th gear at this type of speed to keep vibrations to a minimum. Coming from metrics, it seems counter-intuitive for cruising. Typically, I am used to the lower the rpm vs speed equals better fuel mileage. On my V4 Yamaha Royal Star Venture V4, 1300cc, I can be in 5th gear at 30 mph on level ground and not a hint of vibration, then just roll easily up to whatever speed I want without vibration.
I average 40-45 mpg on the Venture, I am averaging 35-38 mpg with the Road King.
It seems to me that V-twins are a constant effort of rpm vs vibration. I assume that this is a correct analogy?
Old May 21, 2017 | 10:21 PM
TwiZted Biker's Avatar
TwiZted Biker
Vibration has nothing to do with what gear you are in particularly when going up a gear drops RPMS so something's not adding up here. Don't know what to tell you other than if you insist on comparing the differences between the imports and the harley you will never bond with the HD, may not be the machine for you.......
Old May 21, 2017 | 10:22 PM
Veekness's Avatar
Veekness
Well, sir, with a bike that old, a lotta parts like the engine mounts could have detonated or gotten hard, reducing the anti vibration benefit. I don't know if you've changed those out, and they may not be an issue either. Could be just one of them thangs, too.
Old May 21, 2017 | 10:30 PM
ieatchickens's Avatar
ieatchickens
Sounds to me like there's something wrong with your particular bike. My '96 Road King is smooth in all gears.
Since you have a 20 year old bike I would suspect something is wrong. I would first check your motor mounts.
Old May 21, 2017 | 10:36 PM
Hession's Avatar
Hession
My 07 wide glide is similar, it doesn't like to run in the low rpm ~2200 range, it rarely ever sees 6th gear 75mph plus. New handlebar bushings helped but I still won't cruise that low. My 16sgs doesn't have the same vibration no matter what rpm.
Old May 21, 2017 | 11:43 PM
t. sawyer's Avatar
t. sawyer
you are lugging, hd does not like to lug. to high a gear for how slow u are going. just down shift and all is well. its not a metric. enjoy.
kroozeabout.
Old May 22, 2017 | 12:28 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
As a general rule, when "cruising" or on level ground, keeping your RPM's around 2500+/-.
The vibration you describe is your engine's way of telling you that you're "lugging" (RPM's to low for the gear you're using) so shifting to a lower gear is required.
Unfortunately the RK's don't come with OEM tachometers so you may want to check into getting a tachometer installed on your bike.
They have a large variety to choose from these days.
Old May 22, 2017 | 04:38 AM
grbrown's Avatar
grbrown
Wink
Sounds to me that you may simply be riding in too high a gear. You can get away with riding at those revs on a light load, but need to change down a gear for going up a hill or to accelerate. The more you ride the better you will get to know your new bike and it won't take long before the two of you are in sync with each other!
As an Evo owner you should know that we have a separate dedicated Evo section, where you can meet up with fellow owners, so do call by!
Old May 22, 2017 | 05:56 AM
MikeTD3's Avatar
MikeTD3
Does the bike vibrate when you are going 65mph in 5th gear? If not, then 5th at 50mph is simply too high of a gear to be in.
Old May 22, 2017 | 09:23 AM
grubsie's Avatar
grubsie
Just found the EVO section, thanks.
It seems to be like you said about getting in sync with the bike. On light loads, it's fine in the higher gear but need to shift down for hills, etc.
At 65mph in 5th gear the bike is super smooth. Just like 4th gear at 50mph.
So I just need to experience more time on a v-twin. I just figured at 50mph, that any big bore bike would be smooth in top gear. It's just a different riding style that I have to get used to.
Oh, and by the way, I put Avon Cobras on it last week and this bike tracks through corners like it's on rails. An absolute blast.
Thanks for the help.
