Handle bars shaking
Old May 25, 2017 | 05:45 AM
hdwd2000's Avatar
hdwd2000
Default Handle bars shaking
I have a 2013 road glide with 17,000 miles at idle the handlebars and fairing shake violently. Any ideas?
Old May 25, 2017 | 05:50 AM
Ben221's Avatar
Ben221
misread
Old May 25, 2017 | 06:02 AM
Rustrtal's Avatar
Rustrtal
Stopped or going down the road?
Old May 25, 2017 | 06:17 AM
liquidr1's Avatar
liquidr1
At Idle? how bad it the shake. they all shake a little due to rubber mounted engine, but not violently. Id check neck bearings, and then check for a bad or loose motor mount.
Old May 25, 2017 | 06:19 AM
grbrown's Avatar
grbrown
I assume that when you say it does that at idle, you also mean the bike is stationary?! A couple of possibilities come to mind, one being a failed rubber engine mount, the other a fractured fairing mount. What's your bike like while moving?
Old May 25, 2017 | 08:37 AM
Cygnusx51's Avatar
Cygnusx51
With the bike turned off, do your bars have play in them? Riser bushings could be shot.
Old May 25, 2017 | 08:47 AM
bigskyroadglide's Avatar
bigskyroadglide
at idle, all my roadglides, vibrate like a female toy. You should see the fairing shake with the 120R.
However, if the fairing is not properly mounted on the inside fairing support, it will shake more noticeably.
the stock bars should not be moving at idle, however if you have apes, the taller they are the more noticable the shake. my 14"s which are 1.5 factory 47 malos shake a lot more than my Yafee 10s. especially if you have modified the stock engine with cams
Suggestions you have received, such as front motor mount and front engine brace are good ones to check. however do not forget, nothing but 6 screws (in plastic) hold the fairing on if it is not properly engaged on the inside fairing mount.
The bottom supports are to hold the the inner and outer fairing up, not on.
Old May 25, 2017 | 10:39 AM
wideglideCVO's Avatar
wideglideCVO
Change both engine mounts and no play in the handlebar mount and my bars shake at idle without me on the bike. Maybe just normal.
Old May 25, 2017 | 05:20 PM
Kermie's Avatar
Kermie
My 12" MBB's shake a lot at idle, but once I put my hand on the grip it stops.
98custom
Jun 17, 2012 10:43 AM
Mark MPDC
May 1, 2012 10:59 PM
Scooter_092196
May 27, 2010 01:00 PM
WildThang
Nov 17, 2009 10:46 AM
Harleyosentoski
May 20, 2006 10:20 AM
