HELP, replacing handlebars
Old Jun 7, 2007 | 09:55 AM
cboehme's Avatar
cboehme
Default RE: HELP, replacing handlebars
I just took mine apart 2 weeks ago and is very easy. There are 2 screws under the handle bar lock trim ring (the trim ring just snaps on). Then you need to remove the headlight trim ring. Then it's the ring that hold the headlight in place (3 screws). From there you will remove the headlight bucket that is held in place by approximately 10 or so screws. This will leave you access to remove the front trim piece that is held in place by 1 nut. After removing that nut you will be able to rotate that piece up (lifting from the front)and the back should fall out of a tongue and groove shape at the wind deflector. The last step is to loosen the screw that holds the wind deflector down. I hope this helps but probably not the best directions.
Old Jun 8, 2007 | 10:43 PM
cardoctor's Avatar
cardoctor
what bars are you switching to . i just purchased an 06 custom. the bars arnt very comfortable
either that or the seats the problem.
Old Jun 8, 2007 | 11:45 PM
nb472's Avatar
nb472
Check the DIY section. Complete instructions for a RKC are there. Yours shouln't be much different.
Old Jun 9, 2007 | 12:34 AM
redhwk44's Avatar
redhwk44
Hey Rico, not to keep harping on about the manual but it has very precise photos, and directionsto help you understand what everyone is talking about.
Good luck!
Jeff
Old Jun 9, 2007 | 01:31 AM
blfrgrkcustom's Avatar
blfrgrkcustom
I put harley beach bars and the seat refitted by a seat shop and the bike is great now. The stock bars were cramped on the seat made my legs numb.
92oldskoolxlh
Apr 29, 2013 05:06 PM
azzdog
May 6, 2011 06:31 AM
mjaw
Apr 17, 2011 01:24 PM
Spills
May 29, 2010 09:03 AM
shoveldog
Apr 15, 2008 10:31 PM
