ABS plug adaptors?
Old Sep 3, 2017 | 05:35 AM
KumaRide's Avatar
KumaRide
Originally Posted by Thezooboss
The 2-different type ABS sensor plugs I started this stream about. Both were told to me to be 2012 Road King compatible.
Definitely not oem and I think that is your problem. Are you trying to chrome out the bike or fix an abs braking senser issue? I'd put oem parts on to verify all is good, then move onto chrome goodies if that is what you are wanting to do.
oem looks like this:
http://www.ebay.com/itm/11-12-13-Har...-/331989199874
You can buy just the plugs/connectors if you want to replace them.
35 72607-08 HOUSING, 2 WAY PIN 1 4.49 3.99
36 72608-08 TERMINAL PIN, 16-20 AWG 2 2.99 2.99
37 72610-08 SEAL, 18-20 AWG (WHITE) 2 0.49 0.49
38 72639-10 SECONDARY LOCK, 2-WAY SOCKET, CONDUIT 1 0.99 0.99
40 72607-08 HOUSING, 2 WAY PIN 1 4.49 3.99
41 72608-08 TERMINAL PIN, 16-20 AWG 2 2.99 2.99
42 72610-08 SEAL, 18-20 AWG (WHITE) 2 0.49 0.49
43 72639-10 SECONDARY LOCK, 2-WAY SOCKET, CONDUIT 1 0.99 0.99
Look at front and rear wheel for sensor parts.
http://partsfinder.onlinemicrofiche....0MODULE%20(ABS
Old Sep 3, 2017 | 10:40 AM
Boomer1143's Avatar
Boomer1143
As KumaRide pointed out definitely use OEM sensors. That just might be your problem. The ABS light stays on until the bike is in motion. The light will not go out until you start to ride.
Old Sep 3, 2017 | 04:12 PM
Thezooboss's Avatar
Thezooboss
3rd Gear
Originally Posted by SBates08
Do you have the sensors rotated against the stops? Also, is the light staying on while riding or have you not ridden the bike and the light is staying on when idling in the shop?
Yes....rotated to stops....stays on while riding...I'm workin on it ....time to flush anyway...These shinny ones protect the bearing more. I bought an Axle that cam with the sensor the matching spacer for rt side and end caps...problem, unrelated to the light being on, was the plug was square sooooo... I got the one pictured matched with a rear sensor, that came as a working set. I will send a picture...When I flushed brakes(with ABS) on my truck the ABS light went on when I flushed and the ABS light went out after I added and bled calipers...Truck didn't move...TDK...
Old Sep 3, 2017 | 04:36 PM
Thezooboss's Avatar
Thezooboss
3rd Gear
Axle I bought for 60$ came with goodies, wrong plug for front sensor ...It's straight I will use it...
Double f'd... Ok if you guys are following this lol; this was the Rear(working) sensor I bought that I got credited for that happens to be a OEM front(notice 1/8 inch wider than rear OEM sensor)...sooooo I have this one on the front till I flush an whatever i have to do to get the light off....Thanks again for valuable info you guys...
Old Sep 3, 2017 | 04:39 PM
Thezooboss's Avatar
Thezooboss
3rd Gear
Like sand through the hourglass.....I will let everyone know in case someone else runs across this plug shape problem.....lol P Friend PerryNelson on Facebook if you want.... I'm the guy with the bikes(with red wheels) in front of the 4th ave Jail
Bpercle25
Wheels/Tires
Jun 13, 2017 03:19 AM
mkekid
Apr 26, 2015 06:06 PM
toothmansteveb
Apr 12, 2014 06:40 PM
Jesse_81
Feb 15, 2013 05:23 PM
twocoltbob
Oct 29, 2010 03:12 PM
