Clutch Cable Adjustment Problem
Old Nov 4, 2017 | 11:32 AM
Veekness's Avatar
Veekness
Originally Posted by Spider0408
I'll give this try. I didn't realize that the ramp might not be in the full clutch disengagement position. I just assumed it would be. The service manual doesn't say anything about it.
Well, he just described 'the full clutch adjustment'...which you said you did in your initial post...are you saying now that you DIDN'T do this? Because if you didn't, then we've possibly wasted a lotta time in talking all around your problem!!!
Old Nov 4, 2017 | 01:16 PM
btsom's Avatar
btsom
One more thing to watch for, the threads on clutch hub adjuster screw can get burred. If you unscrew the adjuster screw as described in the manual and then screw it back in feeling for the contact point, these burred threads can be mistaken for the binding at the contact point. If that mistake is made, the adjuster screw can be more than 1 turn out from the real contact point and too much cable adjustment (Unscrewing the adjuster too far) can be needed to make up the extra slack in the hub adjustment. To avoid that error, I screw in the adjuster with a wrench handle until I see the disengagement plate (the part the adjuster goes through) seat against the clutch opening in which it is located. If you believe you have found the contact point and that plate is free to move, you haven't really fount the contact point. After the adjuster freely screws in and out, set your 1/2 to 1 turn out and you should be good with the hub adjustment.
Old Nov 4, 2017 | 01:32 PM
TSheff's Avatar
TSheff
Yep, it's real. I hate to put that out there, but I've experienced it on a friends bike. Took the second adjustment to spot it.
Old Nov 4, 2017 | 05:08 PM
Spider0408's Avatar
Spider0408
FYI to responders. I performed the full clutch adjustment exactly as described in the Service Manual. I actually did it twice. The cable problem remained. Bingee pointed out steps that are not in the manual's clutch adjustment instructions. Namely those that fix the lower ramp to the full clutch disengagement position. The manual does not mention this. Others have added some helpful suggestions as well. I greatly appreciate any and all the help I've received. Thank You
I have no intention of wasting anybody's time.
Old Nov 4, 2017 | 06:02 PM
Musician's Avatar
Musician
Similar problem a couple years back. Solved by replacing the cable. Now works like new.
Old Nov 5, 2017 | 12:33 AM
1Canuck's Avatar
1Canuck
If it is not cable stretch then try one more time. I suspect that the position of the rod has not fully opened/released the ball & ramp and you are feeling a false bottom point where they say turn to a light touch. Instructions say turn clockwise until lightly seated. I am saying go beyond that point gently until you feel resistance where you would have to force it.
You need to pump clutch handle 2-3 times each 1/4 turn and not be able to turn the adjuster any further, do so until you reach that point
Then open 1/2 to 1 as you prefer. adjuster cable adjuster at this point it should be good.
Yes I experienced this.
Old Nov 5, 2017 | 12:12 PM
Spider0408's Avatar
Spider0408
Problem solved. Did what Binge said and it worked. I think moving the clutch handle open all the way several times to move the ramp counter clockwise fully down did the trick. That eliminated any spaces between the screw the rod and the ramp.
Old Nov 5, 2017 | 12:27 PM
TSheff's Avatar
TSheff
Good deal and thanks for the follow up FEEDBACK. Importatnt to know results that may help the next guy.
Spider0408
Nov 6, 2017 09:37 AM
BuckeyeUltra
Mar 1, 2012 02:14 PM
Bleachey
EVO
Sep 3, 2011 09:18 PM
Indy Road Dog
Apr 23, 2011 09:08 PM
00glider
May 20, 2006 10:58 PM
