Performance baggers
Old Dec 4, 2020 | 12:10 PM
  #1081
Puglia10's Avatar
Puglia10
Originally Posted by luckyboy06
Hello Puglia10,
I am height challenged and was checking out your cool Road Glide.
Your solution for foot controls are very cool.
I had a machine shop shorten a shifter lever.
The heel shifter keeps my foot from sliding off and makes finding neutral very easy.
Thank you for your posts,
Lboy06.
Glad I could help a little bit. Thats a nice setup. I took 2.5" out of the shifter and brake to bring my feet back. I really liked it but it was really hard to find N (i dont run a heel shifter) and the brake lost enough leverage it made it difficult to really use effectively. The flatter angle of the brake pad is SO MUCH better though.
If I was going to do it again I think I'd try 1.5" instead.
I finally gave up on my experiment and bit the expensive bulltet for Boosted Brad mid controls. Had to get a new pipe too. I'll update soon when I can install them.
Old Dec 5, 2020 | 08:57 PM
  #1082
gartec81's Avatar
gartec81
Back from vacation with the family. Got the pushrod dialed in and rear axle tightened. Fingers crossed no more oil leaks
Old Dec 5, 2020 | 10:11 PM
  #1083
HD Bobber's Avatar
HD Bobber
Sounds and looks killer man! Nice work!
Old Dec 6, 2020 | 08:31 AM
  #1084
gartec81's Avatar
gartec81
Thanks. It's almost there. I have a flush front axle and rear chain drive to install. After that its mids. That should be it for this bike for a while.
Old Dec 6, 2020 | 02:54 PM
  #1085
Nitrochicken's Avatar
Nitrochicken
First post in the thread but have been lurking since the first post.
What mids are you looking at?? Just curious. Currently on a Dyna and can’t see myself with floorboards if I go the Touring route.
Old Dec 7, 2020 | 12:42 PM
  #1086
gartec81's Avatar
gartec81
Old Dec 7, 2020 | 12:50 PM
  #1087
Puglia10's Avatar
Puglia10
Started my mid install this weekend. Boosted brad. So far so good. The pipe side is more involved lol.
Old Dec 7, 2020 | 01:20 PM
  #1088
HighLiner's Avatar
HighLiner
Just curious, why did you choose this set-up over another like Big Bear?
Old Dec 7, 2020 | 01:38 PM
  #1089
Puglia10's Avatar
Puglia10
The short answer is no real reason other than I like the looks better, and found this setup used so saved some money....
.....(although the seller (NOT brad) forgot to send me stuff and he bent something so it actually isnt gonna save me money, and I wouldve been better off buying new, but that was the idea at the beginning lol...oh well)
I think Big Bears solution is a little easier using the dyna mounts, but I didnt really like the two shifter linkages, looks weird. You can also drill the primary out but thats another $500.
They both work and accomplish the same thing, so I'd just pick whatever you like the look of and whatever you can affford.
Honestly, finding and picking a pipe that works is the hardest part.
Old Dec 7, 2020 | 10:24 PM
  #1090
gartec81's Avatar
gartec81
