Performance baggers
Old Jul 30, 2024 | 10:02 PM
  #1951
Rip53's Avatar
Rip53
Old Aug 29, 2024 | 10:11 AM
  #1952
TimJ2110's Avatar
TimJ2110
Originally Posted by gartec81
Wonder if a Lowrider ST fairing would fit/look good on that machine?
Old Aug 29, 2024 | 10:25 AM
  #1953
twowhlrcr's Avatar
twowhlrcr
3rd Gear
New to the Forum......Such a great pic!!!! I was watching King Of The Baggers the other day from Laguna Seca....SWEET!!!
Old Aug 29, 2024 | 02:47 PM
  #1954
TimJ2110's Avatar
TimJ2110
Soooooo:
Actually, don't look to bad IMO....
Old Nov 5, 2024 | 12:41 PM
  #1955
Darkstar_XIII's Avatar
Darkstar_XIII
Old Nov 5, 2024 | 04:55 PM
  #1956
HighLiner's Avatar
HighLiner
Killer pair of fast johnies
Old Nov 5, 2024 | 07:53 PM
  #1957
Rains2much's Avatar
Rains2much
Not sure if mine qualifies. This is more about style and two up comfort.
113” completely rebuilt starting with line honed cases, 10.5:1 mechanical compression, Redshift cam, mildly ported heads, S&S G carb
Custom cut True step tuned dual exhaust. TTI’s
Dyna 2000I ignition
Back cut stock Harley gears
Heavy duty progressive springs, heavy 15 weight fork oil, air at 25psi / stock rear shocks with 10 weight oil at 35 psi
Neoprene front motor mount
Rivera pro clutch with TPP
Solid motor sprocket.
Upgraded late model 4 piston rear brake
In-progress front dual upgrade to 4 piston brake and floating rotors.
‘Fan assisted oil cooler & Love jug fan assisted top end.
Running straight 50 weight until after the first 3k miles.
So far 1200 miles on motor.
Educated guess.. 125-130 hp / 125-130 ft lbs torque. Will dyno.. Softail 127 is first though.
Oddly enough I got over 40 miles per gallon on my recent trip? And we did some over 100 mph cruising and some light to light Shenanigans in that average and I was two up with loaded bags.
Old Nov 6, 2024 | 05:55 AM
  #1958
Darkstar_XIII
@HighLiner
Thanks, I tried to build them similarly, but still be different.
Sadly, the BMW didn't get ridden much this season--so it may have to go.
Old Nov 6, 2024 | 07:01 AM
  #1959
Chad1200's Avatar
Chad1200
Originally Posted by Darkstar_XIII
Who makes that air cleaner cover?
Old Nov 6, 2024 | 07:05 AM
  #1960
Darkstar_XIII
It's S&S, it fits the Stealth Air Cleaner kit.
https://www.sscycle.com/products/dom...-applications/
