Need help!! Front brake bleeding
Old Feb 25, 2018 | 01:27 PM
  #31
Cygnusx51's Avatar
Cygnusx51
Have you tried to loosen the connection at the master cyclinder? Like was said, the plunger inside might be stuck.
Being that it’s a 98, it might not be a bad idea to remove the master cylinder and just rebuild it for peace of mind. The little kit from HD has everything you need and it’s really simple.
Old Feb 25, 2018 | 05:04 PM
  #32
Bryce05's Avatar
Bryce05
Yup tried it all. Even took the line off and blew it out. Think you right, I’m going to order and rebuild kit for the master, should I do HD kit I seen bikers choice had a kit? Also thought about rebuilding the calipers.
Old Feb 25, 2018 | 05:18 PM
  #33
CSMHOG's Avatar
CSMHOG
Before you buy anything try doing a good caliper service. Remove the brake pads and clean the exposed areas of your pistons and try to push a little bit more out and clean that area too. Put some brake grease around the pistons and then push them all the way back in until their flush with the inside surface of the caliper.
Then flush your system again, reinstall your pads and see if you regain pressure. Sometimes the pistons get “off square” from the bores and this sort of resets them. If your having an extreme difficult time turning them or pushing them in, you probably do need to rebuild your calipers.
Old Feb 25, 2018 | 05:40 PM
  #34
Bryce05's Avatar
Bryce05
I’ll do that can’t hurt thanks.
I didn’t see any rebuild kits on the HD site or is that something I have to call them for?
Old Feb 25, 2018 | 06:02 PM
  #35
dawg's Avatar
dawg
Won’t be on the P&A site, it will be on a parts fiche site. 45072-96D is the kit listed for your 98
Old Feb 25, 2018 | 06:16 PM
  #36
CSMHOG's Avatar
CSMHOG
You can get a rebuild kit here. Cheaper and just as good.
http://online.fliphtml5.com/lxnd/iyuz/index.html
Old Mar 1, 2018 | 11:23 AM
  #37
Bryce05's Avatar
Bryce05
I rebuilt the master last night , just waiting on new bleeder screws. Hope I can finally be done with this. Lol
Old Mar 13, 2018 | 06:20 PM
  #38
Bryce05's Avatar
Bryce05
Well after rebuilding the master I had them bleed in 10 minutes. Thanks guys for all the help
Old Mar 13, 2018 | 06:22 PM
  #39
Veekness's Avatar
Veekness
IT'S A MIRACLE!
Gotta feel good now that its done!
Old Mar 13, 2018 | 07:04 PM
  #40
Bryce05's Avatar
Bryce05
Can’t belive it was so easy. Lol
t059736
Nov 4, 2013 01:57 PM
Bedore
Sep 1, 2010 09:17 PM
jayride
Mar 27, 2010 08:41 AM
Bikerboy50
Oct 2, 2008 08:14 AM
WARG
Jul 22, 2008 07:32 PM
