Oil Pressure???????????????????
Old Jun 27, 2007 | 01:51 PM
mwriggs's Avatar
mwriggs
Default RE: Oil Pressure???????????????????
Just talked to the dealer, and much to my surprise it was all finished and in the clean up shop. I was so surprised to hear that it was finished, I cant remember the name of the part, but it is down at the oil pump, something that apprently gets "clogged" on occasions. They cleaned it out, and now I have 5-10# PSI at idle and 30#plus AT 3000 RPM. Shewwww thats a relief. When I pick it up, I will ask again.....however I bet someone on here knows which part it is??!!!
Old Jun 28, 2007 | 08:05 AM
mwriggs's Avatar
mwriggs
Ok Guys, it was the oil pressure relief valve that they had to clean out. Good pressure now.
Old Jun 28, 2007 | 08:28 AM
dog155's Avatar
dog155
Your idle could be set to low.You will never have much idle pressure,these motors are all roller or ball bearings and it is difficult to make pressure.
Old Jun 28, 2007 | 03:45 PM
ClinesSelect's Avatar
ClinesSelect
They replaced my sending unit and now the gauge works perfect. Its the little things that put a smile on your face
Old Jun 28, 2007 | 04:37 PM
RK_Dave's Avatar
RK_Dave
What is considered 'Normal' pressure anyway? Just wondering.
Dave...
Old Jun 28, 2007 | 05:12 PM
jeepster09's Avatar
jeepster09
10 pounds for every 1000 rpm is good.
Old Dec 3, 2007 | 03:08 PM
HDWRENCH's Avatar
HDWRENCH
I am glad the issue's are getting fixed BUT... If pumps are the cause, oil bypass plunger stuck ETC and the engine is really having low oil pressure what are they doing about the wear on the engine?? This is a sore subject with me as i did my time in the HD dealership and have had to put to many engines back together with worn parts , etc as you get told fix the issue and nothing more. SORRY for the rant but if a engine is starved due to oil then it needs to be inspected. Not just well we got it fixed here you go sorry that there was a extra 40,000 miles of wear induced to lack of lubrication.
Jeffbock19
Milwaukee Eight (M8)
30
Apr 21, 2017 08:45 PM
mitchflhx
2014-2024 Touring Models
29
Oct 25, 2016 08:18 AM
crsraider
EVO
23
Apr 24, 2013 05:59 PM
butch63255
Sep 12, 2011 11:13 AM
Jorgy1347
Mar 24, 2007 01:36 AM
