Cam chain tensioner failure
Old Jun 11, 2018 | 06:48 PM
Gregcinhi's Avatar
Gregcinhi
5th Gear
Default Cam chain tensioner failure
my 2006 ultra classic has suffered the dreaded cam chain tensioner failure. I heard the clacking noise and had no oil pressure. Now that I have researched it, I realize that I should have gotten the tensioner checked and replaced long ago. I've opened the cam cover and found a loose pin, a bent tensioner, and a broken piece of black plastic. I don't see the orange plastic shoe anywhere.
Wondering what people think is the best fix at this point. Should I change to the hydraulic tensioner with the kit from Harley? Is it better to change to a gear drive mechanism? Do I have to do anything to make sure the plastic bits and pieces are not somewhere stuck in the engine?
I assume I have to take out the push rods and lifters regardless of which fix I choose. Do I need a special tool to push out (and back in) the cams?
thanks for the advice.
Popular Reply
Jun 11, 2018, 07:15 PM
Veekness's Avatar
Veekness
Before you start getting swept away by all the dreamy things you can do with that engine, you' best get back to the basics and come up with a plan to get all that plastic and metal shavings outta that motor!
Old Jun 11, 2018 | 06:54 PM
DaleMc0622's Avatar
DaleMc0622
Friend of mine just put a S&S 509 gear drive cam in his 05 ultra, he says it is a huge difference, great torque all through the rpm range. If it was me, i would do a gear drive cam while you are in there, not further concerns with tensioners
Old Jun 11, 2018 | 06:58 PM
hbsoldier3's Avatar
hbsoldier3
I did the S&S gear drive with 510 cams on my 04 RK ten years ago. Been running fine for 75,000 miles since, had 15,000 at install.
Old Jun 11, 2018 | 07:15 PM
Veekness's Avatar
Veekness
Old Jun 11, 2018 | 09:35 PM
Screamin beagle's Avatar
Screamin beagle
Yes what veekness said and before you place that order for those gear drives you might want to measure your crank runout, .003 or less for gear drives...hope it works out for you
Old Jun 11, 2018 | 10:46 PM
hattitude's Avatar
hattitude
I hate to be the one to say it, but..... you lost oil pressure, heard clacking noise, and destroyed your cam tensioners... Make no mistake.... you had a major engine failure...
Without seeing the damage first hand, I can't give good advice other than.... If you put your motor back together, without getting ALL the destroyed pieces out of the engine, you run the risk of destroying all your new parts.... and having to do it all again. AND you need to find any collateral damage caused by those pieces before you shut the engine down.
Many will tell you it's time to pull the engine and split the cases to ensure you have them flushed out properly, inspect all, and probably do a rebuild.... some may say time for a remanufactured engine... and there are those who may say to just flush and reassemble with new cam plate, oil pump, oil pan, etc....
Converting to hydraulic tensioners or gear cams is in your future, but there are many things to deal with and decide on, long before that....
If you have a Dealer/Indy/Competent gear-head friend, who's opinion you trust, it's time to get their advice.....
Sorry for your misfortune but good luck on the repair....
Old Jun 12, 2018 | 12:36 AM
Ron750's Avatar
Ron750
How many miles were on the bike?
Good Luck.
Old Jun 12, 2018 | 02:27 AM
Campy Roadie's Avatar
Campy Roadie
Don't forget the oil pan.
Old Jun 12, 2018 | 03:08 AM
Scudda's Avatar
Scudda
^^^ this right here.... I think you are looking at a bigger repair then just replacing the cam plate..I don't see how you will get away with at least splitting and flushing the cases....
Old Jun 23, 2018 | 07:16 PM
Gregcinhi's Avatar
Gregcinhi
5th Gear
Thanks for the advice. I've started the project in my own since my trusted independent Harley mechanic has had some issues. I've gotten the rocker box covers off, the rockers off, the push rods and lifters out, and drained the oil. Found some pieces of plastic in the cam box. Found metal debris in the oil.
my next plan is to pull the pistons and get the cam plate off so I can get to the oil pump. I assume I need to see if there is debris in the pistons and the cylinders.
This might sound dumb, but do I have to replace the oil pan? How do I "flush" things out? I was planning on wiping everything clean but are ther other tricks and tips?
