Streetglide-found a problem
Old Jun 25, 2007 | 11:01 PM
Drum's Avatar
Drum
Default Streetglide-found a problem
Wanted to let you guys/gals know of a problem I had in hopes of saving you some trouble. I have about 1900 miles on mine when I noticed the FM station not coming in real good, I thought it was just my location. Last night we rode about three hours and our friends said that the brake light was not coming on, I also noticed I had no light for the cruise. So today I pulled it all apart to wash it and look for the problem, well I found it.
Might want to check yours and see if the harness is close to the belt. I know it was not that way a few weeks ago, and must have worked it’s way loose and slid onto the belt.
[IMG]local://upfiles/24625/8A10F910084642B69B15C00E10C227CA.jpg[/IMG]
Old Jun 25, 2007 | 11:07 PM
dionne51's Avatar
dionne51
Default RE: Streetglide-found a problem
Wow, that sucks. Minor fix which is good, luckily no other damage than the frayed harness. I'll be sure to inspect mine before departure tomorrow.
Thanks,
D
Old Jun 26, 2007 | 08:23 AM
PapaTravis's Avatar
PapaTravis
Bummer. Shouldn't be to involved to fix, but still a bummer.
onlythebest's Avatar
onlythebest
WOW!
Old Jun 26, 2007 | 08:27 AM
Hardly Dangerous's Avatar
Hardly Dangerous
What is supposed to hold the harness up?
Old Jun 26, 2007 | 08:31 AM
Hogtoad's Avatar
Hogtoad
Thanks Drum, I can only imagine what else is likely to come loose. I'll be checking for that kind of stuff regularly......
[IMG]local://upfiles/22834/B4485A9CF06640D5B9F244801317172B.jpg[/IMG]
Old Jun 26, 2007 | 10:00 AM
04harleyboy's Avatar
04harleyboy
Thanks for the update Drum, I will be inspecting mine tonight, and possible adding a zip tie. Hope you get her fixed up soon!
Old Jun 26, 2007 | 10:08 AM
robandlyn's Avatar
robandlyn
WOW ....
Thanks ...
I'll check our 2 tonight !
Rob ...
Old Jun 26, 2007 | 10:15 AM
jerseyjeff62's Avatar
jerseyjeff62
why is your belt red?
Old Jun 26, 2007 | 01:33 PM
Biggzed's Avatar
Biggzed
I'm assuming that is covered under warranty?
I realize it's a quick fix, but unless people take this kind of stuff to the dealer it will continue to be a problem. One of the quickest ways for any consumer product company to firgure out a problem is to go to the consumer data. That may be a call center, warranty center, or anything like this. At least make them aware of it.
