questions 09 limited classic
Old Jul 8, 2018 | 11:20 AM
hardheaded's Avatar
hardheaded
Default questions 09 limited classic
My younger brother just bought a 09 limited with 13,000 on it for a very good deal. Couple of questions i was hoping someone could help us out with.
1. Does this thing have cats on it and where are they at ? Head pipe or mufflers ?
2. Does anyone know what year HD changed the bolt style in the riser to adjust the handle bars ? I know they used to contact the radio.
3. How do you extract the codes from this bike ? Just in case.
4. Any differance in the injection system with the O2 sensors being up by the exhaust ports ?
THANKS !
Old Jul 9, 2018 | 12:51 PM
hardheaded's Avatar
hardheaded
No One ?
Old Jul 9, 2018 | 01:23 PM
SBates08's Avatar
SBates08
The first Limited wasn't produced until 2010. Makes a difference in answering your question about the Cat.
Old Jul 9, 2018 | 01:40 PM
hardheaded's Avatar
hardheaded
i'm sorry it's a 09 electra glide classic . I thought it said Limited on the front fender though ?
Old Jul 9, 2018 | 02:07 PM
SBates08's Avatar
SBates08
If it's an 09 and not a California model there is no Cat on that stock exhaust.
Old Jul 9, 2018 | 08:20 PM
bmaier's Avatar
bmaier
I have an 09 Ultra Classic with 127,000 miles. As previously mentioned 09 is the last year without a cat in the headpipe unless California model.Has the crossover pipe go under for less heat on the passenger. First year of the new improved frame/swingarm. No contact between handlebar riser and radio on mine. Different size O2 bungs up top that wouldnt be subject to reported "crosstalk" that the bungs mounted down low by the collector could repoertedly be subject to. Same 50mm throttlebody that was introduced in 08 and was used through 2016, so the injection system is the same. Great year.
Old Jul 9, 2018 | 10:06 PM
hardheaded's Avatar
hardheaded
THANKS ! This is great information.
Old Jul 13, 2018 | 06:42 PM
jerryleejr's Avatar
jerryleejr
I’m gonna have to pick your brain sometime I also have an 09 and hope to put that many miles on it...
JJ
Old Jul 13, 2018 | 10:47 PM
IKnowNot's Avatar
IKnowNot
As said, if it is a 49 state bike it should have no CAT.
For the trouble codes, check
https://www.hdforums.com/forum/touri...tic-codes.html
As for the Handle bar clamp bolts, see the attached Service Bulletin M1289
File Type: pdf
C908
May 25, 2012 06:45 AM
2001Roadking
Jan 2, 2011 09:03 PM
davewear
Dec 23, 2010 08:35 PM
KCFLHRC
Jun 27, 2010 08:00 AM
Ben U
Oct 17, 2008 10:39 AM
