09 compensator
Old Sep 22, 2018 | 12:10 PM
hardheaded's Avatar
hardheaded
Default 09 compensator
Is there a way to tighten up the spacing in the 09 compensator ? Shims maybe to take up some slack ? Can the spring pack be replaced ? I believe the spring pack is part of the rotor assembly. I know the baker is the real fix, but my brother is trying to buy alittle time with this one. We are installing the Baker Attitude Adjuster and will have the comp. off anyway. Just seeing if we can get it to be alittle less noisy. THANKS !
Old Sep 22, 2018 | 01:03 PM
cncmike's Avatar
cncmike
I had my spring pack replaced last year when a spring broke. The mechanic said the rest of the compensator was fine.
Old Sep 22, 2018 | 09:38 PM
hardheaded's Avatar
hardheaded
Was this on a 09 ? I believe the later ones had the flat type springs that were replaceable.
Old Sep 22, 2018 | 10:04 PM
cncmike's Avatar
cncmike
Yes the springs looked like flat rings. They are part of the cover for the stator. It’s replaced as a unit. I have an ‘09 Streetglide
Old Sep 23, 2018 | 07:53 AM
todd-67's Avatar
todd-67
Looking at the parts diagrams the 09's look like different units in regards to the spring packs. I know that they are forward compatible. No sure how many parts you would have to replace to get that set up in the 09.
I am not at home right now but I have a whole unit out of a 2010 that still had some life left in it when I switched over to the SE unit.
Old Sep 23, 2018 | 09:42 AM
F150HD's Avatar
F150HD
unclear why you're removing the comp to put in a chain adjuster, unless the Baker Attitude requires that (?)
Regardless, if comp is off (or coming off) IMO why not just replace now and save a headache next summer or thereafter.
Old Sep 23, 2018 | 09:57 AM
hardheaded's Avatar
hardheaded
Yep , the Baker requires the removel of the comp. spocket to install. My brother wants to buy alittle time with this compensator for awhile to save some money, he just bought this bike and it's really not to bad right now.
So what i'm getting out of this is you can buy the spring pack for the 09 compensator ? I guess i'll give the dealer a call ( i really hate the idea of that ).
Old Sep 23, 2018 | 10:09 AM
F150HD's Avatar
F150HD
interesting, didn't realize one had to pull the entire comp to put in a the Attidude Adjuster.
09- didn't see the specific model in your original post....assuming a touring model.
Old Sep 23, 2018 | 08:34 PM
highmarket's Avatar
highmarket
On my 09 at 60, 000 miles I added one more spring disc from another comp. It worked great for 20, 000 miles, at around 80, 000 miles my shift shaft seal started leaking , when I opened the primary up the spring disc's were starting to where thru the spring cup so installed new SE comp .
Rking80
Jul 10, 2018 09:47 AM
bigdog1949
Jun 6, 2012 09:27 PM
Raptor1956
Jun 19, 2009 02:00 AM
slick690uk
May 3, 2009 09:29 AM
customsoftail200
Northeast
Dec 19, 2007 08:04 PM
