Replacing Lifters
Old Nov 7, 2018 | 06:29 AM
roundy's Avatar
roundy
Default Replacing Lifters
Hey Guys,
I am just replacing my lifters (originals with 72k miles on and 2002 bike); will also be putting S&S Quickie Pushrods in...
The anti-rotation roll pins, should these move much? Is there a tolerance for them?
Old Nov 7, 2018 | 07:08 AM
ROCKOUT Rocker Products
Sponsor
Zippers recommends .002-.004 clearance, and has oversize pins if needed.
One thing you can try... the flats on the lifters are not always ground evenly from side to side. Try turning the lifter around & measure again
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Nov 7, 2018 | 08:39 AM
roundy's Avatar
roundy
Interesting, thanks for that....the clearance between the pin and lifter is good I think; it was side to side movement I have, not sure if that is an issue?
I meant to ask as well, the S&S lifters came pre-soaked in oil, assume this is just assembly lube that I don't need to clean off or anything?
Old Nov 7, 2018 | 03:47 PM
bundy43's Avatar
bundy43
I would call S&S to see about side to side movement, I don't think there should be any.
Old Nov 7, 2018 | 07:52 PM
23Seven's Avatar
23Seven
My Knight Prowlers don’t move... I think if there was any movement it would be another addition to valve train and nobody wants that!
Old Nov 7, 2018 | 09:42 PM
Sponsor
I think the OP means side to side movement of the pins... I don't think a little matters.
Old Nov 10, 2018 | 01:04 PM
roundy's Avatar
roundy
Did a little video tonight before the covers went back on, don't think its anything to be concerned about??
Really frustrating today also as the pushrod kit arrived.....or not as the case may be; I only got pushrods! Ordered this https://www.harleycustom.co.uk/produ...-93-5122/42209 from AR Harley in the UK and it was only the rods, not as the listing would describe!! I think they've screwed up the listings :-(
Old Nov 10, 2018 | 02:50 PM
Guntoter's Avatar
Guntoter
Don't see any problem with those pins, that side to side is not an issue. As to the pushrod problem, just go to the H-D dealer and get the Screamin Eagle pushrods. I use the straight ones, not the tapered, and they work great and come with the proper tube parts to make them easy to install and adjust. You can get the tapered also, they just cost more and unless you have high lift cams they really aren't needed.
Old Nov 12, 2018 | 03:46 PM
roundy's Avatar
roundy
Got the S&S ones sorted, being switched for me with a discount on the difference as their supplier screwed up the web details!
Yves Cuillerier
Jun 17, 2019 07:55 AM
Robottom
Aug 3, 2018 03:29 PM
98hotrodfatboy
Engine Mechanical Topics
Jun 8, 2018 01:18 PM
predatornut
22
May 24, 2017 10:11 PM
martin10
23
Dec 18, 2016 02:21 PM
