Rear sprocket
Old Dec 15, 2018 | 09:54 AM
NELS's Avatar
NELS
Default Rear sprocket
10 RK has anyone changed the rear sprocket (68 tooth) to a 70 Tooth of a triglide?.
Old Dec 15, 2018 | 10:40 AM
multihdrdr's Avatar
multihdrdr
If you're asking if you can just swap them out? ... No, you can't. It's actually closer to a 2008 IDS system than a 09-later
Old Dec 15, 2018 | 11:52 AM
btsom's Avatar
btsom
How close would that make the 6th gear engine rpm about equal to the 5th gear rpm in the pre-6 speed machines?
Old Dec 15, 2018 | 02:31 PM
grbrown's Avatar
grbrown
The trikes use a wider 1 1/8" belt, compared with the solo models and 30/70 with the identical cush-drive rubbers to the '08 solos. Even a 2-tooth change in size could require a different length of belt.
Rear drive ratio will become 32/70, the same as the original belt drive models. Are you referring to the twincam 88 models, when asking about 5 spd rpms?
Old Dec 19, 2018 | 11:39 AM
Sarsippius's Avatar
Sarsippius
This might be slightly off topic, as this info is for Softails and not Touring models, but there is still a ton of great info regarding gear ratios, belt widths etc. Maybe there is some info you can use. If not, it's still pretty damn interesting.
https://www.hdforums.com/forum/softa...p-to-13-a.html
FrogHair
Sep 27, 2018 04:15 PM
deadhawg
Dec 2, 2017 01:11 PM
Ink83
Apr 4, 2016 07:43 AM
superstandardFL
Apr 3, 2013 02:26 PM
garyw
Aug 9, 2007 06:44 AM
