2000 Electra glide
Old Jan 5, 2019 | 07:11 PM
Jeremiah Cobbs's Avatar
Jeremiah Cobbs
2nd Gear
Default 2000 Electra glide
I'm on edge about buying a 2000 electra glide from the dealership. The lining of the tank is coming off. Which means the fuel pump is definitely clogged. What other problems am I about to run into. Worst case scenario.
Old Jan 5, 2019 | 08:28 PM
702's Avatar
702
Many will tell you that the MM fuel injection system is crap, but I haven't had any trouble with mine other than a fuel pump replacement at 35k miles. The pump and filter is still available should you need it.
The other issue to be wary of is the cam chain shoes.
Will the dealer take care of the tank?
Old Jan 5, 2019 | 08:34 PM
tfi racing's Avatar
tfi racing
If the price is right, and you can do the work yourself, go for it. If you are not into turning wrenches, it's likely best to move on to a newer bike.
Old Jan 5, 2019 | 08:40 PM
Jeremiah Cobbs
2nd Gear
Default 2000 electraglide
For extra on the price tag. I'm confident I can do the job myself and just take the tank to a machine shop or something but it's just not in my best financial interest to let the dealership deal with it. I just want to know worst case scenario
Old Jan 5, 2019 | 08:41 PM
Jeremiah Cobbs
2nd Gear
Also the bike only has 14 k on it
Old Jan 5, 2019 | 08:52 PM
Jeremiah Cobbs
2nd Gear
yeah I'm comfortable doing the work but the only injectors I can find is 2001-2005. Does it still work for the 2000? If you know the exact parts I'm gonna need a list would be greatly appreciated.
Old Jan 5, 2019 | 09:31 PM
svarnster's Avatar
svarnster
does it run?
how bad is it peeling? mine has slight peeling but not a problem.
why do u think it needs injectors? filter should catch anything well before it gets to the injectors. may need filter or clean filter. [ injectors changed in 02 to Delphi system]
cam shoes should be inspected.
what is the price? if it is a good buy I would not hesitate.
good luck
Old Jan 6, 2019 | 12:11 AM
Uncle Peepers's Avatar
Uncle Peepers
As a former owner of a 2000 Electraglide, I'd advise taking a pass. Fuel injection related items will become increasingly difficult to find; some are nearly impossible now. Before I totalled mine, I was seriously considering converting it to a carb. And has been said, the cam chain tensioner shoes will need inspection and monitoring.
IMHO, there are just too many good bikes out there right now to justify taking a chance on anything the least bit iffy.
Old Jan 9, 2019 | 11:56 AM
Jeremiah Cobbs
2nd Gear
The fuel pump is weak so thats why it doesn't want to run. it turns over just fine. My thoughts are to replace the pump, fuel filter, pressure reg. and with the tank I was thinking acetone.. what are your thoughts am I missing anything?
Old Jan 9, 2019 | 12:00 PM
Jeremiah Cobbs
2nd Gear
its a clean bike 5000 out the door when I worked at the dealership they took it in on a trade didn't even look at it. its only got 14k.The fuel pump is weak so thats why it doesn't want to run. it turns over just fine. My thoughts are to replace the pump, fuel filter, pressure reg. and with the tank I was thinking acetone to get out the peeling liner .. what are your thoughts am I missing anything?
