2012 ultra classic limited fuel pump problem
Old Jan 11, 2020 | 06:31 AM
Eddie_Mush_1113's Avatar
Eddie_Mush_1113
Stage III
Default 2012 ultra limited fuel pump problem
Hey new to the forum thing but was told a lot knowledge is here ..I have a 2012 ultra classic limited an started to have problems starting the bike so I thought it was dead jumped an it started up ride about 20 mins turned it off for a few then it crunk right back up stoped at one more location an it didn’t wanna crank up ..I noticed at this point I didn’t hear the fuel pump come on ..I thought it was my battery at first an slapped a new one it but that wasn’t it ..I checked my fuses but they all seem to be good..I took the relay out but it also didn’t look bad ..then again not really sure how to tell if a relay is bad ...I wiggled lines an pushed all wire connections in and still nothing my last an final thought would be the fuel pump itself.. is there anything I’m missing?? ..thanks in advance
Old Jan 11, 2020 | 06:47 AM
Johnnypop's Avatar
Johnnypop
Is the starter turning over. If not it could be your fob battery that is not responding to let the bike start. If the starter is working then fuel pump would be next. Also check the fuse to the fuel pump is good with test light. Fuse might look good but still be blown. Do you have dash lights?
Old Jan 11, 2020 | 06:51 AM
Eddie_Mush_1113
Stage III
Yea it wants to start but seems no fuel is getting to it ..cause all the lights work I just don’t hear the fuel pump come on when I turn the key over ..I’ll have to get a light tester
Old Jan 11, 2020 | 08:03 AM
joe buck's Avatar
joe buck
Kill switch ?
Old Jan 11, 2020 | 08:08 AM
702's Avatar
702
Is there another relay in there that you could try swapping?
Old Jan 11, 2020 | 11:56 AM
Eddie_Mush_1113
Stage III
just swapped a relay an it came on ..thanks a million ...I was getting worried there for a second
Old Jan 11, 2020 | 03:55 PM
702's Avatar
702
Awesome, I'd replace them all just to be safe.
Old Jan 12, 2020 | 07:59 PM
F150HD's Avatar
F150HD
mileage? when was the fuel filter in the tank last changed?
jlsmthrs97
11
Jun 12, 2022 02:31 PM
zschaeff205
Jul 14, 2016 10:41 AM
rlchristensenmd
Apr 17, 2012 11:32 AM
Moboy
Dec 20, 2010 12:07 AM
wes
Apr 18, 2006 12:31 PM
