Vibration
Old Sep 1, 2020 | 06:07 PM
user 47363638's Avatar
user 47363638
Default Vibration
My 2019 Roadglide has a vibration at 2100-2500 rpm and most noticeable when I down shift and come down to 2500 rpm.
Old Sep 1, 2020 | 07:46 PM
MyFavRk's Avatar
MyFavRk
I just went through this with my bike , certain rpm's would cause it to vibrate through the road pegs and handle bars . It turned out to be a set of bad bearings in the front wheel . I removed both brake calipers and gave the wheel a hard spin , heard a tapping noise when I put my ear up against the axle . I knew it wasn't engine related because I pulled the clutch when it was doing it and it didn't go away .
Another thing worth checking , would be your brakes , when up off the ground , make sure your brake pads are releasing / retracting . Could need a good cleaning , check your pistons for debris and clean up the calipers and brake pads ( replace them if necessary ) . Not sure if abs brakes could be causing this , never had them .
How old are your tires / miles , front tire cupped , could be the reason for the vibration as well .
If your vibration is more of a handle bar shaker / wobble , could be steering stem bearing , need to be checked / re-torqued . Could be other things as well , like wheel alignment or swing arm bearings .
Maybe be a little more descriptive when describing your vibration , hopefully it's an easy fix .
user 47363638
Milwaukee Eight (M8)
Sep 1, 2020 08:44 AM
PatS
Aug 30, 2018 06:40 AM
Drunk Monkey
Exhaust System Topics
Aug 16, 2009 01:35 PM
rahall
Jun 9, 2008 11:45 PM
em2780
Aug 12, 2007 07:41 PM
