Dang sissybar
Old Jul 27, 2007 | 06:55 PM
StreetglideOK's Avatar
StreetglideOK
Default Dang sissybar
Ive heard horror stories, but today I lived it and installed the docking hardware today for the backrest. The directions were 90% useless. It showed putting spacers in behind the rear saddlebag mount, and doing so put the bags out of alignment with the front mount. I didnt snag pics of the outcome, was good and ready to get out of the heat. Should the saddlebag mount be spaced out further then factory to accommodate the sissybar? Seems to be clearing as is now.
Old Jul 27, 2007 | 07:05 PM
oldfartjc's Avatar
oldfartjc
Default RE: Dang sissybar
What type of bike do you have? I have those spacer washers on mine that came with the Docking Kit and they don't really cause any problem and space it out the correct distance.Too bad you didn't do a search, as there are many helpful hints thathave beenposted on this forum that would have saved you a lot of time and frustration. The destructions are almost totally useless like you said.
Old Jul 27, 2007 | 08:58 PM
StreetglideOK
07 Streetglide here. The destructions, even the woman called them that,lol, called for a spacer behind the rear saddlebag bracket 9/16" thick. The bolt that was to go with it, too short, and if I used the long bolt, then the mounting brackets were way off. I figured out the trick to getting the bolts to line up, and got the docking hardware on at least. Ill have to look thru some posts and see what I can find. Hopefully someone has posted pics.
Old Jul 27, 2007 | 09:28 PM
oldfartjc's Avatar
oldfartjc
ORIGINAL: StreetglideOK
I guess if I looked at your name a little closer I would have known what bike you had. Here is a link with some tips that might help you.
https://www.hdforums.com/m_356976/tm.htm
Old Jul 27, 2007 | 09:30 PM
Scott_WI's Avatar
Scott_WI
I hear you! You need to read my post here, on my install problems:
http://forums.delphiforums.com/n/mb/...mp;msg=26799.1
And yes, those spacers are definately not supposed to be installed, despite what the "destructions" state.
Thanks,
Scott
Old Jul 27, 2007 | 09:53 PM
SIM's Avatar
SIM
Search is your friend on this site. This is for a road glide, but not much different.
http://www.moatsfamily.com/Docking_Station_Install.pdf
Old Jul 27, 2007 | 11:40 PM
oldfartjc's Avatar
oldfartjc
ORIGINAL: Scott_WI
Thanks,
Scott
Why not, they don't present any problem and they move the hard bags out just a little bit. Mine is fine with the spacers.
Old Jul 28, 2007 | 07:54 AM
Scott_WI's Avatar
Scott_WI
On my 07 RK the spacers made the bags stick out way too far. It didn't look natural. In fact without the spacers everything fits as original, so I'm not sure why the spacers were suggested. Nothing is touching / rubbing without the spacers. Maybe I read the instructions wrong and spacers are not need on 07's, but I had thought I read them correctly.
Thanks,
Scott
Old Jul 28, 2007 | 08:58 AM
Tech2's Avatar
Tech2
I left out the spacers. The spacers push the rear saddlebag mount bracket out too far for my liking, and cause the bag to flex when mounted. I just slipped the rear saddlebag mount bracket behind the rear docking hardware bracket and left out the spacers. Doing it that way keeps the rear saddlebag bracket in line with the front saddlebag bracket. The saddlebag lid is damn close to the rear docking point, but it doesn't rub and I've had no trouble opening and closing the bags.
ksummers
Nov 19, 2017 07:43 AM
clackavosticus
Oct 26, 2016 07:13 PM
atrain68
Jan 6, 2015 03:45 PM
flhxmc
May 26, 2013 03:28 PM
CntryFun
Product Reviews
Oct 23, 2005 05:36 PM
