Re installing inner fairing
Old Oct 19, 2020 | 09:15 PM
Mikehoncho636's Avatar
Mikehoncho636
Default Re installing inner fairing
Can I curse on that forum ?! Haha
i am having the hardest time to align the inner fairing on my 2020 SGS . Any tips? Videos ? 😂
Old Oct 19, 2020 | 09:26 PM
CoolBreeze3646's Avatar
CoolBreeze3646
I have to ask why did you take the faring off a new 2020 SGS? And do you have an HD Service Manual.
Old Oct 19, 2020 | 09:53 PM
Mikehoncho636
factory 47 bars !
i don’t have a manual 😫
Old Oct 19, 2020 | 10:16 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Push, Pull, Squeeze, Flex, Force and finally get a hammer. That's all I got!
Old Oct 19, 2020 | 10:37 PM
rcrankin's Avatar
rcrankin
This is what is required for a 2014. You will need to raise the inner fairing assy a little (2"-3"), then slide the assy over the top mounting holes that are part of the triple tree. The metal strut behind the fairing plastic is shaped slightly like C channel for rigidity and to keep the inner fairing in place when the blinkers or auxiliary lighting is removed. I'm not sure what info is in the manual for this; but, if you are still struggling with it let me know and I will take a look.
Thanks,
Rob
Old Oct 20, 2020 | 07:22 AM
thebreakman's Avatar
thebreakman
Put screws in loosely on the top ones and manually move the bottom screw holes to where you need it. It takes alittle patience.
Old Oct 20, 2020 | 08:34 AM
426power's Avatar
426power
Old Oct 20, 2020 | 10:43 AM
sanman4ever's Avatar
sanman4ever
Put it back on the same way it came off....
Old Oct 20, 2020 | 01:08 PM
gravnov's Avatar
gravnov
When I installed my (painted) inner fairing, I used some silicone spray...and everything slided in place.
Old Oct 21, 2020 | 01:16 PM
barneyboy's Avatar
barneyboy
Originally Posted by Mikehoncho636
factory 47 bars !
This video is from Factory 47. It's a 2017 SGS. Lengthy video, but skip to 46:00. The guy makes it look super easy, but he also took the time to ensure everything was routed correctly beforehand.
JKSHYT
Sep 8, 2020 05:40 AM
Steelernation
Mar 19, 2018 08:38 AM
UltraNutZ
Audio Systems
Feb 25, 2013 08:23 AM
jimsflh
Feb 9, 2010 03:46 PM
aclass
Jan 1, 2009 03:52 PM
