injector cleaner
Old Aug 1, 2007 | 09:56 PM
joe v's Avatar
joe v
Default injector cleaner
has anyone used any type of injector cleaner in their bike if so what brand or type thanks
Old Aug 1, 2007 | 10:18 PM
beemer737's Avatar
beemer737
Default RE: injector cleaner
Chevron techron.
Harley fuel additive.
I use something every month or so. No problems noted from either.
Old Aug 1, 2007 | 10:26 PM
drdiesel1's Avatar
drdiesel1
Chevron with techron is the only thing to use...Don`t over do it....It works the best by far.
Old Aug 2, 2007 | 03:01 AM
PapaTravis's Avatar
PapaTravis
How would you over do it?
ORIGINAL: drdiesel1
Old Aug 2, 2007 | 06:35 AM
drdiesel1's Avatar
drdiesel1
Adding more than the recommended amount to the fuel you have in the tank..[8D]
Old Aug 2, 2007 | 06:47 AM
Pastor John's Avatar
Pastor John
Funny you should mention this....
My '07 Road King with 13k miles is running a little rough from time to time with excessive engine vibration at a particular range of rpm's. I've checked everything I can think of and technically the bike should be running fine. It doesn't happen all the time, and at one time I thought it was probably a tank or two of poor grade fuel. But it's happening too often for it to be that - it will sometimes run fine and the next time I ride it will be rough again.
Would you expect that the injectors could be the problem? I suppose I will run some injector cleaner and see if that clears it up.
Old Aug 2, 2007 | 07:01 AM
drdiesel1's Avatar
drdiesel1
Yes the new injectors are Laser cut. The multiple nozzle holes will clog easy. I have found it necessary to treat my BMW (Bosch injectors are prone to clogging) about every 10 to 12 K.
Use the Chevron with techron cleaner.
You can find it at local parts suppliers. Use as recommended and your idle problems will clear-up within 50 miles of operation.
Old Aug 2, 2007 | 08:09 AM
Chicago Spike's Avatar
Chicago Spike
Techron Fuel System cleaner is about the only cleaner that most vehicle manufacturers recommend. I will split a 12oz bottle over 3 tankfills and do this maybe twice a riding season.
Old Aug 2, 2007 | 10:40 AM
baldjohnny's Avatar
baldjohnny
Would an injector cleaner affect a O2 sensor? I know it doesn't in a auto, but just curious if there's any difference between that and the wideband sensors I'm using with my T-Max. Seems I remember reading in the instructions that addiives could cause problems ...
Old Aug 2, 2007 | 10:57 AM
Chicago Spike
Can't see why, o2 sensors are o2 sensors. They are the same in cars as they are in bikes. If it does make any difference, it would only be for the tankfull the additive is in. Once it's gone, the fuel system, and o2 sensor, will be cleaner but the additive is gone
