Weird one…
Old Apr 19, 2022 | 10:05 AM
Outcast_Animal's Avatar
Outcast_Animal
Stage IV
Originally Posted by ahhlou
Disconnecting the security system would require replacing the flasher module. I would disconnect the radio and then the tuner to eliminate them. After that, pull the fuse for the flasher module, then other fuses one at a time to locate the circuit that is causing the problem...
Thanks for the tip, I’ll try that and let you know
Dolce
Electrical/Lighting/Alarm
Jun 8, 2016 08:03 PM
GeorgiaGlide
Jun 22, 2013 10:15 AM
buba6
Mar 7, 2011 12:08 AM
softail78
Jun 20, 2010 11:26 PM
Roadie4
May 27, 2007 08:51 PM
