Speedometer question
Old Sep 20, 2023 | 08:22 AM
hattitude's Avatar
hattitude
Originally Posted by pcmc2
Ok I get it's the VSS. How do you remove it without unbolting the starter? My starter sits right over the VSS on my '98 RKC.
Sorry, I have nothing to offer for your specific year/model bike. I've never worked on a '98 RKC, so I've never seen the VSS on one.
I can only say I don't recall an issue dealing with the few VSS cleaning and/or replacements I've done. However, they were on Twin Cams.
Old Sep 20, 2023 | 04:43 PM
kevin_n's Avatar
kevin_n
Heard from Dakota Digital and they recommend testing the VSS before sending the gauge in. I’m thinking when I take it apart I might just replace the VSS instead of having to take the starter out twice. They did also say it is possible that a solder in the gauge could be getting weak. But I will take the fairing off first and make sure all connections are tight before I do anything else. I’ll keep you guys posted.
Old Sep 21, 2023 | 05:33 PM
kevin_n's Avatar
kevin_n
Question for you guys that replaced the VSS, was there a code stored for it. I just checked for stored codes and there was none.
Old Sep 22, 2023 | 08:58 AM
hattitude's Avatar
hattitude
I've had one go bad with no code.....
I have read that a bad VSS with no code is not unusual...
Old Sep 22, 2023 | 06:10 PM
kevin_n's Avatar
kevin_n
thanks
GPRiders
2018+ Softail Models
28
Apr 17, 2024 06:52 PM
ecrow0497
Jul 16, 2023 08:50 AM
Spec36
Feb 11, 2019 03:27 PM
slimmer
Sep 15, 2014 06:33 PM
x1rider
May 12, 2012 10:25 AM
