Speaker Switch on Road Glide
Old Aug 26, 2007 | 11:31 AM
cglofland's Avatar
cglofland
Default Speaker Switch on Road Glide
Anyone have an idea why the speaker switch is on the Road glide. I have the electrical diagnostic manual, it shows headset A, headset B, Assy enable, and I think Gd going to the switch. I have heard that this is for a tour pak if installed. All I want to do is to get audio out from the radio to input to my Nady bike to bike comm. Radio doesn't have audio out so I thought maybe I could get it from connector 27A on the radio, pins 13 and 21. Anyone have ideas.??????
Old Aug 26, 2007 | 11:46 AM
EZ2Rider's Avatar
EZ2Rider
Default RE: Speaker Switch on Road Glide
Its there so you can add a Tour Pac with rear speakers if you want. You also have an aux. switch for other applications.
ez
Old Aug 26, 2007 | 11:55 AM
cglofland's Avatar
cglofland
But is there a way I can tap into the audio out to provide for audio in to the Nady Radio?
Old Aug 26, 2007 | 11:58 AM
sugarbear's Avatar
sugarbear
I am assuming it is the same switch on ultras One position is for front speakers the next for front and rear if equipped and the next for headset
Old Aug 26, 2007 | 01:15 PM
Wecroft's Avatar
Wecroft
On my Ultra here is what the switch does
Forward position: CB, Intercom and Radio comes thru the helmet
Center Position: CB and Intercom thru the helmet,,Radio thru speakers
Rear Position: Intercom thru helmet,,Radio and CB thru Speakers
Old Aug 26, 2007 | 02:45 PM
SteelCityScooter's Avatar
SteelCityScooter
ORIGINAL: sugarbear
Take the time to read your owners manual, the "speaker" switch on the inner fairring cap is for switching audio sources between the speakers and the helmet headsets.
"Headset A"All the way forward (no light) Everything through the headsets (Radio, CB, Intercom)
"Headset B"Middle (light on) Radio through speakers,CB and Intercom through headsets
"Assy Enable"All the way back (light on) Radio andCB through speakers, Intercom through headsets.
GND is for the ground wire for the little ight in switch
Your Intercom Audio will only work through the headset speakers to maintain privacy.
Speaker Fading (front to rear) is done through the softkeys on the radio, or by using the left volume switch on the handlebar. (Push in till it goes to fading screen on radio, then up or down to move the audio front to rear.)
To the original question of the thread.
The "Speaker" switch on the fairing cap does not have audio signals attached to it, it is connected to the radio control circuits (follow the wires back through the wires from the switch, then through the "interconnect harness" and you will seee they only go to the radio and not the speakers)
To enable the rear speakers when installing a tourpak and then installing rear speaker PODs, you will have to have the Dealerturn them on through the radio by flash downloading the ECM. (The Ultra is the ONLY model that comes with the rear speakers, factory enabled. in the HK Radio)
So tapping on to any of the wires there will not get done what you want.
Old Aug 31, 2007 | 12:03 AM
cglofland's Avatar
cglofland
Thank for a good detailed answer. I have bought my interconnect cable, now I will need the dealer flash.
mtbottles
Aug 29, 2016 02:59 PM
pipes_6
Audio Systems
Jul 2, 2014 11:01 AM
mccstevie
Sep 2, 2012 05:11 PM
trucker7775
Jul 3, 2012 07:37 AM
dix
Jul 18, 2007 03:22 PM
