Crank position sensor problems
Old May 7, 2024 | 09:37 PM
memphisharley's Avatar
memphisharley
Yeah. If the CKS is smeared, OP got big problems.
mine was...I guess those chunks of piston skirt played a roll.
Old May 7, 2024 | 09:56 PM
Max Headflow's Avatar
Max Headflow
Did he post more than one thread? Don't see anything about pistons here..
Old May 8, 2024 | 06:08 AM
memphisharley
nah..that was the issue I had when my sensor was trashed. swapped the sensor before I tore it down and the bike still ran but damaged the new sensor in short order which precipitated the teardown.
Attached Thumbnails Crank position sensor problems-20231110_185443.jpg   Crank position sensor problems-20231120_181442.jpg
Old May 8, 2024 | 06:18 AM
smitty901's Avatar
smitty901
CPS will throw a code. They can be intermittent. CPS is a simple magnet they can go bad but not often . Check for a code.
Old May 8, 2024 | 08:05 AM
Vernal's Avatar
Vernal
@Pistol Pete 1911 Go to this FaceBook site and click on Files, type in 2006 in the search bar and scroll down to find the Electrical diagnostic manual. Download it to your hard drive.
The manual tells how to get the DTC's and in Section 5 the is a troubleshooting guide for starts then stalls.
Old May 8, 2024 | 08:21 AM
Max Headflow
Another way to ding the CKS is to twist the crank..
Old May 8, 2024 | 08:33 AM
Max Headflow
Originally Posted by Pistol Pete 1911
FLHTCI 2006, 88 cubic inch twin cam, Arlen Ness big sucker, Freedom true duals, Screaming Eagle clutch package and heavy duty spring. No cam chest upgrades as of yet I figure we would like to solve this non-run issue before we dive into the camshafts.
backfiring and coughing, then limp mode, and then once in the garage and shut off it would not start again
FWIW, the 06 does not have a limp mode.. More of a dying mode. Limp modes were coined for fly by wire EFI. The 06 is still fly by cable.
Old May 8, 2024 | 08:44 AM
memphisharley
yes...i see a runout check in his future. when i had this carnage the runout was still in spec at 0.006.
Dconnell
EVO
18
Mar 12, 2024 08:20 PM
pcmc2
EVO
Mar 11, 2024 12:22 PM
slideman67
Jun 14, 2021 10:22 AM
Dangermouse
Feb 23, 2013 01:59 PM
rking2000
May 16, 2008 11:50 AM
