Cruise control problem
Old Jul 27, 2024 | 06:56 PM
RollaMo's Avatar
RollaMo
Originally Posted by Capo180
Thanks for the reply’s.
even when I disconnected the clutch switch I still have the same problem. I removed the clutch switch and disconnected the connector for the left side control switch housing, still the same problem
But what about the cruise switch itself.
Your description of the issue is the same as what I experienced on my old Street Glide.
Push the cruise button, Orange light would come on. Then pushing down on the switch to "set" the speed, nothing would happen.
Sometimes it worked, but most times not.
Dealer replaced the actual cruise switch, and the issue was resolved.
Old Jul 28, 2024 | 12:18 AM
400web's Avatar
400web
Glad to here you got it sorted
Old Jul 28, 2024 | 02:09 AM
Capo180's Avatar
Capo180
4th Gear
the set switch self its fine. I took the “set” switch out, check the wires from the switch to the ECM and measured it with the multi meter, all good.
Old Aug 13, 2024 | 04:35 PM
Capo180's Avatar
Capo180
4th Gear
Still the same situation here..
Old Aug 18, 2024 | 07:01 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Try this test:
Old Aug 18, 2024 | 08:30 AM
Capo180's Avatar
Capo180
4th Gear
Originally Posted by CoolBreeze3646
read the post please
ramu3527
2014-2024 Touring Models
24
May 3, 2024 06:02 AM
bigpappa160
May 27, 2016 12:09 PM
Larry Nawara
Sep 14, 2013 05:05 AM
kredin
Sep 1, 2011 06:33 PM
redrock1951
Mar 14, 2011 02:42 PM
