Another comp sprocket issue
Old Aug 21, 2024 | 07:54 PM
  #31
Rounders's Avatar
Rounders
I get they needed something for what is going on now. Was it a case of harley selling us crap and letting us be the R&D for future bikes? My 95" non epa bike has done ok on old comp. So I suspect 96" would too. I am not a hard rider. But you were not hearing about issues on bored 88s.
Guessing on numbers 103s were probably ok too
Old Aug 21, 2024 | 09:15 PM
  #32
hardheaded's Avatar
hardheaded
I don't understand why HD changed the comps to start with . I have friends who have 96 and 124 S&S Evo engines that see burnouts and wheelies without any comp problems. Way more power than any twinkie or M8 has.
The comps, all the rubber isolator crap in the rear wheel and the slipper clutch were all designed to protect HD's loose machining and crappy flywheels in the engine.
Old Aug 21, 2024 | 09:38 PM
  #33
Ohio HD's Avatar
Ohio HD
Harley changed the compensator as well as utilizing isolation mounts to make a smoother riding motorcycle. The late compensator vs. the early style has more travel, and larger springs. To accommodate that they needed the springs on the inside near the motor and the sprocket away from the motor. That late design didn't allow for lube to sufficiently reach the center of the compensator. The latest HD compensator does get lube to the center of the compensator so they hold up very well. I run a 124 TC in front of the late HD compensator, no issues.
Early
Late
Old Aug 27, 2024 | 02:14 PM
  #34
bcool's Avatar
bcool
Originally Posted by Rounders
They are known to be a problem. That said I suspect it is riding style, I got 75k on mine, but ride like a wuss.
Cuious what direction he goes for fix. You got to epoxy pieces on for Harleys fix. Manowar has one, but has to be rebuilt 30-40k which is annoying. But maybe only for hard riders? There are threads with people with conflicting opinions.
Rounders, I have often wondered if premature failure of clutch and drive components are due to heavy handed riding style.
I've been riding since I was twelve, and rode the snot out of many bikes, but at 70 years of age I now ride like a wuss, as you say. Not afraid to cruise the super slab at 85-90 and pop it over a 100 occasionally, but I'm easy on the clutch and shift between 2-3K.
What is your opinion? Your advice is valued.
2011 Ultra 52K miles.
Old Aug 27, 2024 | 04:41 PM
  #35
flhf150's Avatar
flhf150
I do the same as you. Easy on clutch and usually take it to 3k before shifting. Try not to let the motor lug either. Under 2k, I down shift.
Old Aug 27, 2024 | 06:01 PM
  #36
Rounders's Avatar
Rounders
I like to also cruise high speeds. But I am not much for hole shots.I have 75k on my 2007 comp. Even if it fails tomorrow I am past what ever one says it should be. It is on my list of stuff I have to address. And I hope I do it before it fails.
None of the solutions jump out at me to give me direction on which one to buy, and known are overly cheap. Not saying any are bad.
Old Aug 27, 2024 | 06:50 PM
  #37
flhf150's Avatar
flhf150
I just changed the comp on my 2012 RG, so I should be good with that for a long time. My 2000 RG has 136,000 miles on it and never changed the comp. Never made noise.
Old Aug 31, 2024 | 08:32 PM
  #38
cncmike's Avatar
cncmike
Maybe I missed it somewhere in the conversation, but is the compensator actually damaged? You know you can buy the replacement rotor all by itself from Harley or aftermarket for around $160 and just put it all back together unless there is something more wrong. Those rotors are known for coming apart like that. I am on my third at 161,000 miles.
Old Sep 1, 2024 | 08:15 AM
  #39
flhf150's Avatar
flhf150
The picture shown is the cup that houses the bellville washers.
Old Sep 1, 2024 | 07:01 PM
  #40
Mongo1958's Avatar
Mongo1958
Originally Posted by flhf150
Forgot to mention he has 40,000 miles on it.
I'm surprised that it lasted that long.
Yup it's a common issue with the 96" TC bikes.
EasternSP
Mar 7, 2022 11:05 PM
EndriStrati
14
Nov 20, 2021 09:14 PM
Dieselsoftail
27
Jun 5, 2019 01:14 PM
randazlr
Sep 29, 2017 04:23 PM
Traceman
Mar 26, 2011 07:09 PM
