Tire plug kit
Old Feb 5, 2025 | 03:51 PM
  #31
KK0G's Avatar
KK0G
Originally Posted by skills
Yes, I found that the lube these plugs come coated with sometimes just wasn't enough. The head on the plug would fold over and distort in the applicator tube when the plunger started forcing the plug through that little tube. I think just about anything with a bit of "slip" would work. Spit on it if there's nothing else available.
Are we still talking about tire plugs?? 🤣
Old Feb 5, 2025 | 05:18 PM
  #32
MRFREEZE57's Avatar
MRFREEZE57
That is why I always carry a tube of vulcanizing cement in my plugging kit, it acts as a lubricant and inserting the plug is much easier.
Old Feb 5, 2025 | 06:38 PM
  #33
Rusty Springs's Avatar
Rusty Springs
Whether or not you use cement may depend on the plug manufacturer. I recently bought a Safety Seal plug kit and it came with a lubricant. That's the first I've heard of tire plug lube.
Old Feb 5, 2025 | 07:02 PM
  #34
hamah's Avatar
hamah
Originally Posted by Ultra103
And you are doing what?
It's funny that this discussion started over me asking the resident expert which type should be run in a car tire, the butthurt followed quickly.
yeah, I'm sorry about your butt hurt. No insult was intended.
Old Feb 6, 2025 | 06:57 AM
  #35
Kenny94945's Avatar
Kenny94945
The quality of the reamer and plug insert tools are assets.
I have had better luck with "string" type over mushroom type plugs.
Vulcanizing cement is highly recommended as plug lubrication and to seal the final repair.
The "trick" to over-inflate the tire so the plug inserting is easier can be a good trick.
Whether a 12-volt battery or engine spark plug/ cylinder air pump is best, I have no comment; but CO2 cartridges would be my last choice for air.
Flats suck and roadside repairs are not so much fun either.
Mentioned was the "new" screw-in plug.
I have never used these, yet could be efficient; I am curious.
Old Feb 6, 2025 | 07:15 AM
  #36
702's Avatar
702
No matter what type of plug you choose, it's not a good time fixing a flat if the plug dried out and is no good when you need it. If you want a shelf life for them to be nearly as long as a Twinkie, vacuum seal them before you put them in your kit. Same goes for the little tubes of rubber cement.
Old Feb 6, 2025 | 07:17 AM
  #37
Goose_NC's Avatar
Goose_NC
Yes!! I order new plugs every 4-5 years for that reason. Almost time to do so again as I bought my 2019 FLHTP in 2021.
Old Feb 6, 2025 | 07:54 PM
  #38
Kenelz's Avatar
Kenelz
I'm a magnet for stray nails/screws, even my lawnmower has a plug in one of the tires.
I thought I was going to get by with no plugs in my Fatboy this time, as its getting close to being worn out, but a couple weeks ago, I noticed I picked up a small nail, and plugged it.
Then, yesterday I noticed a silver spot on the same tire, it must have been there a long time because it was another small nail, but the head was completely worn off. I was dropping a pound or two of air pressure every couple weeks for quite a while, which wasn't enough to think I picked something up.
Both nails were about the same size, makes me wonder if I picked them up at the same time. The one nail the head was gone, the other about half gone.
When I plugged it yesterday I was thinking of this thread, and over inflated to try the above suggestion, but when I reamed it, all the air was gone before I could get the plug in, so that didn't work for me.
I don't know how many plugs I have used over my lifetime, I get the cheap tarred chord kits from Walmart or Harbor Frieght, and every plug has lasted the remaining life of the tire. I have never had one fail.
Old Feb 7, 2025 | 12:56 PM
  #39
ewhitefo's Avatar
ewhitefo
Silly addon question, wouldn't the air pump for the suspension work on airing up the tire? I assume it would, never tried it but in a pinch it should I would think.
Old Feb 7, 2025 | 01:07 PM
  #40
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Sure, but you would have to pump it 150,000 times...
craigcrewcheif
May 15, 2014 02:08 PM
Turbo Flux
Mar 28, 2010 12:33 PM
hotshot
Jul 26, 2009 10:33 AM
G wizz
Jun 1, 2008 06:49 PM
Opossum
Sep 22, 2007 10:48 AM
