Some people tell you the meter is not accurate. Maybe, mine have been ok. But I doubt they should spike even if not accurate.
Side not, I always wanted digital meter, can tell alot. But to lazy and cheap.
If you want a digital volt meter just to confirm, you can buy very cheap ones that plug into your cigarette lighter. Probably less than $10 and 5 seconds of time.
That's cool. I could Google. But do you have a link to one you tried
Is it ok to test the new stator after installed before reinstalling the chain/sprocket and primary cover?
Sure. I would charge battery first. Just start bike with stator not plugged into volt regs. Rev it up should get 80-100 volts AC. Around 20 per 1k rpm. I take it to 4-5k RPM
I would suggest that the location may not be the best as the line may have other loads on it which would lower the voltage. A better location to use is the battery tender plug.
These are handy.. The Battery tender is only accurate to +- 0.1 volt tho..
I may be misunderstanding you rounders. Are you talking a digital voltmeter for the bike to replace the factory meter?
I was, but cig lighter is easy
