Electrical issues
Old Jun 10, 2025 | 09:11 AM
  #81
Hoyt 1911A1's Avatar
Hoyt 1911A1
Originally Posted by dwhit6419
Agreed Hoyt. Calling a dealer not to far from me just to see if by any luck they offer a pigtail. If not, I'll have to do the stator change out. Not the end of the world...
Now that's a thought. Once you get it torn down to where you can access the stator it might be possible to just replace the wiring. I suspect the original unit doesn't have a replaceable pigtail, but once you get it to that point you might be able to repair it. Just to be safe though once you get down to that point if you think it has been grounding out might not want to trust it long term.
Old Jun 10, 2025 | 09:21 AM
  #82
dwhit6419's Avatar
dwhit6419
Pretty sure If I open it up it'll get all new. Only want to do it once...
Old Jun 10, 2025 | 12:21 PM
  #83
Rounders's Avatar
Rounders
To my knowledge they do not make pigtails for stator side. They do for DC side to battery.
The grommet is known to leak with no official fix
Old Jun 10, 2025 | 02:26 PM
  #84
dwhit6419's Avatar
dwhit6419
I bit the bullet and ordered a stator. I don't like the looks of my plug, and it isn't worth taking a chance IMO.
Old Jun 10, 2025 | 07:06 PM
  #85
Rounders's Avatar
Rounders
It sucks, but right thing to do. Would need to do sooner or later.
Not hard job, but tedious.
One dumb thing I just learned few years ago was to take bolt completely out of shifter and it will come of splines easy. I used to loosen and fight. I was working with friend who is indie. He must have thought I was a born. Told me to grab shifter of tranny on bench, and I said I had to work it off.
I'd look at shifter shaft seal. I would probably do primary bearing too
Old Jun 12, 2025 | 01:31 PM
  #86
dwhit6419's Avatar
dwhit6419
Originally Posted by Marrin1933
I always use HD or Cycle Electric when replacing a regulator or stator...
I have a cycle electric stator coming next week.
Old Jun 13, 2025 | 07:21 AM
  #87
dwhit6419's Avatar
dwhit6419
Just an update while I wait for the new stator to arrive. I've been taking rides locally and the bike has been running perfect, with no codes or check engine lights coming on. I appreciate everyone's input on this issue, and I've definitely learned a lot. I'm hoping in the future this thread will help someone else with similar issues. Also hoping the change out will go easily...
Old Jun 13, 2025 | 07:40 AM
  #88
memphisharley's Avatar
memphisharley
if all is well save stator install for winter project.
Old Jun 13, 2025 | 07:43 AM
  #89
dwhit6419's Avatar
dwhit6419
That's kinda what I'm thinking at this point.
Old Jun 13, 2025 | 07:52 AM
  #90
Rounders's Avatar
Rounders
I can't say I would not consider this. And do a few other things since it is a part.
But I would also be nervous on road
This is why nice to have two bikes, and even two almost identical. But I still like to spend summer riding.
A pro could do this in hours. Call it a week of week nights after work. Not rushing. Day off, day on, day to do it. Day to replace bearing in primary and shifter shaft seal
I get it those are sand bagging. But I am talking easy after work. And nothing goes quick. Especially if you never did it
In past I was removing floor boards,maybe my least favorite part. I worked with indie, I think he just loosened remove shifter bolt completely.
Clutch left hand threads. I would not do with out manual.
Could even consider a night to rebuild clutch, not saying I did every time.
If you wait to winter I might consider sprocket shaft seal behind stator. I replaced mine year after I replaced stator. Probably was already bad.
