FLHTCU Oil Change
Old Oct 26, 2007 | 09:39 PM
dstockton's Avatar
dstockton
Default RE: FLHTCU Oil Change
About 3.5 quarts is all I can get in mine at oil change. These bikes don't like to be overfilled. It's probably better to run a little low than have too much oil in the bike. The tank shouldn't be full or the oil pump can't siphon and return oil correctly. That and it pukes oil out the filter all over the bike.
Old Oct 26, 2007 | 11:35 PM
Lost1's Avatar
Lost1
ORIGINAL: thatguy
What type of oil are you guys putting in at 500mi.... knowing that at 1000mi the dealer is going to drain it all out. Manual says diesel grade 15W40 if I need to top up.... so what is everyone using at 500mi.... I do plan on using synthetic after the 1000mi service.
You shouldn't need any oil at 500 miles, unless you're changing it...
Old Oct 27, 2007 | 12:38 AM
thatguy's Avatar
thatguy
I am changing it cause I won't have enough mileage for the 1000mi service and I dont want to leave the break-in oil in the engine over the winter... even the HD manual says to replace the oil for off season storage. Plus, I think it is a good idea to get rid of the oil after the 1st 500 miles... oil is cheap compared to a V-Twin engine.
Old Oct 28, 2007 | 11:21 AM
Facetious1's Avatar
Facetious1
ORIGINAL: thatguy
I went ahead and spent the extra to do syn 3 for my 500. Though it may be a waste of money.... I feel getting the synthetic in asap will ultimatly do my bike good (just IMO-from all the years of playing with hot motorcross engines) I do plan on looking for Redline 20/50 for engine and primary and 95/145 for the tran @ 1000 (get rid of that dang shifting clank).
sac130e
Aug 29, 2016 06:42 PM
bpd138
Apr 9, 2014 09:32 PM
KevenW
Oct 1, 2011 07:00 PM
casadelray
May 13, 2010 06:18 PM
maintainin
Oil Archive (no new posts)
Apr 13, 2009 06:26 AM
