117 Build on order
Old Oct 30, 2007 | 09:24 PM
karlrockdrain's Avatar
karlrockdrain
Default 117 Build on order
My '07 SGlide had required a new crank from HD. Decided to get Steve at GMR to build me a crank. All this talk of the HQ113 builds made me realise that i had the perfect opportunity to get my cases bored. I have a 107 kit ready for the SGlide ,but i'm selling that now and getting the Axtell barrels/pistons from GMR and going up to the 117 build. Will run the 625/585 GMR Andrews cam, HP INC 55 Throttle Body, Fatcat 2-1 and the R&R Cast heads and should run at 11 or just under on Compression. Timken upgrade as well.
I have no doubt that this will be one sweet little build and there are going to be a few surprised guys on bikes at sets of lights.
My old 107 kit in my Dyna ran 121hp/128tq and iwould be real happy to get these sort of numbers again in my bagger.
karlrockdrain
Old Oct 30, 2007 | 09:30 PM
PhilM's Avatar
PhilM
Default RE: 117 Build on order
So, did you sissor the the 07 crank?
Sounds like your new one will be quite nice too. did you already have these heads or will they be new for this build ?
Old Oct 31, 2007 | 03:17 AM
karlrockdrain
Phil, 24 thou on the runout for the Street Glide.
I had the heads sitting to go with the 107 kit and after having used R&R Cast heads on my Dyna, i wanted to keep them. GMR will be getting a -10cc Reverse cut piston to suit my heads and all should be sweet. Gotta love a oversquare motor. Bring that Torque on!!!!!!!!!!!!!!!!!1
karlrockdrain
Old Oct 31, 2007 | 06:23 AM
Manish_Hawg's Avatar
Manish_Hawg
Phil,
I talked to a friend (lead mech)at the stealer (trying to get a discount) and he pulled both of the HD cranks. He told me they are made in the exact same way and doesn't understand why the cheaper one would scissor. He told me they use it all the time inbuilds. He said the only difference he could see is the more expensive one is billet. I'm not doubting your statement at all cause I have noclue when it comes to these machines. But he is going to call the HD tech line and call Kevin @ HQ and ask why he thinks it should scissor.
I would love to save money but I would hate to haveminescissor trying to save $300
Old Oct 31, 2007 | 07:36 AM
PhilM's Avatar
PhilM
ORIGINAL: karlrockdrain
Wow.......024" is pretty tuff. So, it sounds like your crank was beginning to sissor. Just a tiny twist throws a ton of runout into the crank. The stock 05 crank I just pulled out my 05 had .0025 (2.5 thousands)
Rod ~ WHat you've been told is ABSOLUTELY BS! The "GOOD" crank is manufactured by Jim's and is a very nice and sturdy piece. The "Cheap" one is neither of those. It's likely made overseas (probably in a plant where they use lead based paint on you kids toys. The quality difference is "day& night". Personally, I would build the 95, using your stock crank, before I'd put one of the cheap cranks in a 113. FORGET that cheap POS!
Old Oct 31, 2007 | 07:50 AM
karlrockdrain
Phil,
The Street Glide was a Demo with 6000miles on it when i brought it. Completely stock and when the Dealer went to fit the 107 kit- discovered the run-out.
My "07 Dyna was even better. Put the 107kit in last October on a new bike. Bike ran perfectly, but i wanted more power. Upped the heads to R&R and put in Gear Drives S&S 620 cams. Pulled 139hp/128tq. That Dyna flew along. Run out was not checked at either build. Checked the runout after we floated the Valves one night and chewed up a set of gear drives and run out was 39thou. Dealer is now checking all '07 bikes for run out. Lesson learned by all.
Dyna has gone back to stock and is being sold and i'm now moved over to the SGlide and hoping to turn it into a Custom. Have BadDad building me a newFeder/Bag setupand Hogpro suppiled a 18' with Dual 6 pistons for the front. Want to have show to match the go.
karlrockdrain
Old Oct 31, 2007 | 09:39 AM
Manish_Hawg
[]LOL
I believe you Phil. My buddy works at the dealer and he has HD blinders. He was going to do my build but I may have to go elsewhere. He keeps trying to push the HD kit and SE cams, but I believe HQ will be head and shoulders above them. He has never heard of HQ but yet I see the comparison on this forum.
Old Oct 31, 2007 | 05:30 PM
HarlyFan's Avatar
HarlyFan
Has there been much discussion on the 124 or the 130 cu in builds?
Old Oct 31, 2007 | 11:08 PM
Dalton's Avatar
Dalton
Karl,
I checked the runout on mine a couple of months ago, it was .012, beyound the HD original spec of no more than .010 on the newer engines but was told by the dealer that the runout is now acceptable at .012. Bottom line is that I am doing the 120" HQ build and am going with the JIM's 4-5/8" crank. I dont know if my 103" build was too stout for the crank, if the crank originally had escessive runout or both, but I am not chancing it on this build.
I shoulda checked the runout when I did the original build but being a new engine at the time, and not going to gear drive cams, just didn't check it.
Old Nov 1, 2007 | 03:53 AM
karlrockdrain
Dalton,
I think that there would be plenty of Dealers/Indy's who would not have considered to check the run-out before the '07 came out > I look at it as a win- Harley pay for the motor to be pulled out and put back in and i can bulletproof the bottom end and case bore at the same time for not alot more coin. I would have not gone that route if the cases didnt have to come out. Being in the land of Oz, i would more than likely just brought a big inch motor from S&S and such instead.
karlrockdrain
adm
Engine Mechanical Topics
22
Jul 26, 2016 07:20 AM
6 gun
Jan 26, 2015 04:21 PM
txphatboy
Mar 5, 2012 06:29 PM
Harleypingman
Dec 28, 2007 03:25 PM
Boxer Harley
Feb 13, 2007 09:35 PM
