"DIY MODS" and TRICKS to SAVE $$$$$$
(if the link doesn't work search for Dioder Light Strip, part 501.194.07. A 4-pack costs $50. These can be multi-colored but they also have just white.
They are meant for household current but there's a transformer that brings it down to 12v DC. I unsoldered the wire from that box and just ran it to my battery with an inline fuse. I then mounted one light just inside the Tour-Pak below the lock, another one on the lid. I put the other two underneath the TP along the sides. The control was mounted on the inside of the TP up front.
Multi-purpose: now I have lights for the TP and lights for the saddle bags. Or just static lights for fun (they look great.)
http://cgi.ebay.com/ebaymotors/25-5-...item5d257f737b
Surely the factory ones can be secured; otherwise what's the use?
So I bought 9 ft of aux cable, a 90 degree connector and a few beers and got busy.
I ran the cable from the furthest corner of the tourpac, thru the hole for the other cables & wires, under the seat, under the tank dash and out the front to the bikes frame. Then up into the fairing, where after taking the radio out, I pulled just enough of the cable thru the radio mounting hole to be able to plug it into the 90 degree fitting and then into the aux port of the radio. Re-mount the radio being sure to get as good a seal as possible and you're good to go.
A few other tips......
-I put a piece of heat shrink tubing over the connection between the cable end and the 90 degree fitting to keep them tight and protected from water
- Zip ties are your buddy. Use them wherever you have to to keep the cable neatly bundled with the existing wiring
- once the cable is pulled into the fairing, check and re-check to make sure you have enough slack in the cable when turning in either direction. More is better.
- At some point i'll re-run the cable under the tank itself instead of the tank dash.
- To keep the connection tight and waterproof, I added a piece of heat shrink tubing to the connection between the 90 degree fitting and the aux cable plug.
https://www.hdforums.com/forum/touri...-solution.html
