[quote=FLHTCU2007Ken;9042477]That's a great idea with awesome innovation but the edges are still susceptible to rust. I drag the left one most every day??? Steel rusts. How do we stop it?
Here's my solution for draggin' the boards. Was a motor cop for a long time and these were on all the bikes. The mechanics changed them almost as often as the oil. Get some angle iron and attach a piece to the underside of each board. I used an existing hole and pop rivets. A plus is in the dark you get a nice light show.
Just finished reading every post here. Some pretty good stuff, but I feel really, really inadequate because I don't have an automatic garage door opener.
Hinged older hard bags?
Has anyone tried to add or fabricate a set of hinges on older non-hinged hard bags? I'd like to hinge mine as they're kinda a PITA to mess with otherwise.
Don't know if anyone has done this, I got the idea from my Dad....
What I did was:
Step 1: I gathered my tools and materials.
Once the filter was off the bike I used a Grinder with a Zip Cut Blade and a Propane torch. I decided to go with automotive seam and joint sealer to install the K&N element. I used a K&N filter from my last bike a Honda VTX1300. My father used one from a car, he re-folded the pleats to fit the Harley housing
Step 2: Took my OEM filter off the bike.
Step 3: Used a propane torch to remove the stock filter element (this will make it replaceable if you ruin the K&N). I applied gentle pressure on the housing. I heated the metal housing with light passes of the torch until the glue released.
Step 4: Mocked up the filter housing with the spacers in place and measured the inside diameter of where the filter sits.
Step 5: Cut the filter material from the K&N filter to the measurement from step 4.
Step 6: The filter is like a spring and tries to jump out of the housing. I used a coat hanger to hold the K&N in the desired shape for stability. It is a one shot deal getting the new filter in the housing.
Step 7: I used seam sealer to hold the spacers in place. Then I filled the recessed portion of both halves of the housing.
Step 8: Placed one half of housing on table, placed preformed filter from step 6 in housing, placed other half on top (watch the spacers). I pressed the housing together and placed a weight on the top.
Picked up an '07 SG a while back and being an old guy, I was having trouble unscrewing the dipstick,my grip isn't what it used to be. I saw a tool advertised for $20 to do the job but I like making things. Here's my solution. Start with a 2" pvc coupler. Insert a socket, I used a 36mm, into one end so it doesn't deform. Insert into a vise. Heat with a heat gun. It will take no more than a 10 count to soften the plastic. Insert the dipstick and apply a putty knife to form to the dipstick. Let it cool. Continue until all sides have been formed. Whole lot easier to remove the dipstick now. Pics attached in order.
Ingenious. I reckon if a dipstick was really hard to get off you could put a hole on each side on top of the coupler to stick a long screwdriver or something of the like through the holes to use as a leverage turner.
