Fatcat Issue
Old Dec 21, 2007 | 04:23 PM
Badbagger's Avatar
Badbagger
Default Fatcat Issue
Got the new build done and Fatcats installed. One issue with the pipes though. They supply a POS clamp and when tightened up and torqued, the muffler slips backwards about 1/2". Pipe for a Harley indeed wonder if the pulled the pipe off the shelf for a Honda instead lol. Maybe they had their "H's" mixed up! Seriously, I can't be the only one whose had this issue. Aside from calling D&D and getting a real clamp, what have yall tried. Other than that, a great pipe. Got the
quiet baffles and I am here to tell ya, they are anything but quiet!
Old Dec 21, 2007 | 04:36 PM
gilbos440rt's Avatar
gilbos440rt
Default RE: Fatcat Issue
When I put mine on I noticed the slots were shorter than the clamp by a bit, so when I installed it I tapped the clamp back till it was just barely pass the slot's but covering them then tightened down. Mine hasn't slipped any so far, knock on wood I had read about it before so when I put mine on I was looking for that problem, I think the slots should have been longer, I was going lenghten them if this didn't work I got the ~Stealth~ baffle too, throaty at idle and cruising, REALLY talks when wack it hard going down the road though
Old Dec 21, 2007 | 05:10 PM
nvsteve's Avatar
nvsteve
Tighten the clamp when hot, let it cool then tighten again.
Repeat a couple times.
Old Dec 21, 2007 | 05:13 PM
PhilM's Avatar
PhilM
Another thing.... make sure the clamp is DIRECTLY over the slits in the muffler when you're tightening it down. Some have said they had to make those slits a little longer too.
So.... do you have the bike back now? Does it run "a little different"?
Old Dec 21, 2007 | 05:58 PM
rpt63's Avatar
rpt63
I had the same problem, and I ended up drilling a little hole right in front of the rubber dampner at the rear of the mounting bracket for the muffler and putting a smallnut and bolt,no more slipping after 5000mi.
Old Dec 21, 2007 | 08:56 PM
rideon's Avatar
rideon
Try taking some emery cloth and sanding up the mating surfaces, chrome on chrome don't hold well.
Old Dec 22, 2007 | 07:41 AM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: rideon
Exactly..............the new chrome parts are too slippery to have any holding power. Rough them up a bit, make sure the clamp is positioned right, and tighten it down super tight.
Mine has never moved from the first time I installed it, but I know of 2 guys around here who had their slide back on them.
Steve
Old Dec 22, 2007 | 09:42 AM
musclehead's Avatar
musclehead
I lenghtened the slots in mine with a cut-off grinder which has resolved the problem.
Old Dec 22, 2007 | 04:03 PM
Badbagger's Avatar
Badbagger
Solved. Silicone inside the muffers and then drilled and tapped the bracket that the muffer bolts to under the saddle bag and ran a bolt thru it. That should help it from sliding back and also roughened up the chrome so there's something to bite on.
Pipes are great. I was really pretty surprised how loud the quiet baffles are lol. Granted it is subjective and that all builds will be different etc. But damn, they are NOT a quiet pipe. Not complaining lol... they sound awesome.
Steve, sure glad you convinced me to go the quiet baffle route or I'd been changing the baffles out I am sure.
Bakerbob
Jan 22, 2017 03:44 PM
Gordon61
Exhaust System Topics
May 17, 2016 03:38 PM
JimmieJack
Sep 10, 2012 10:33 PM
'05Train
Mar 27, 2011 02:55 PM
dawg
Sep 14, 2007 06:15 AM
