Question on checking primary chain adjustment
Old Jan 27, 2008 | 05:58 AM
steveh326's Avatar
steveh326
Default Question on checking primary chain adjustment
I am past due on checking my primary chain adjustment. Do I have to drain the primary fluid before I can remove the inspection cover and make any adjustments if necessary?
Old Jan 27, 2008 | 06:43 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Default RE: Question on checking primary chain adjustment
No, but put a block of 2x4 or something similar under the kickstand to getthe bikestanding close to upright. Else you will lose some of the oil in the primary and have a mess. Best time to check it is when you are changing primary oil.
Old Jan 27, 2008 | 08:45 AM
HogBack's Avatar
HogBack
Like UC said, the block helps. Most important it helps with the angle to work on the primary side, and it helps a bunch when you go to put the quart back in. Do not forget it is at a 'bad' angle and later knock it off balance.
Good Luck
Old Jan 27, 2008 | 08:49 AM
electaRICK's Avatar
electaRICK
steve,,,, how many miles , you at?
Old Jan 27, 2008 | 09:17 AM
dog155's Avatar
dog155
You should consider changing to a self adjuster.
Old Jan 27, 2008 | 09:20 AM
steveh326's Avatar
steveh326
15k, was supposed to check it at 10k but didn't cause I was in a hurry when I changed all the fluids... runs fine, but figured I would check it anyway this time around. just changed the oil and trans, but its like 25 degrees in the driveway... think I'll wait a couple days when its warmer to change the primary fluid and check it when I do that.
jack49's Avatar
jack49
If you have a jack,just lift the bike enough to straighten it up.
That will make it easier and no chance of oil spilling out.
Old Jan 27, 2008 | 10:16 AM
harleykris's Avatar
harleykris
While it's apart, put on a self adjuster. Well worth the money.
Old Jan 27, 2008 | 10:25 AM
Roadking04's Avatar
Roadking04
I have heard that some people are having trouble with the Harley self adjusters. They overtighten the chain.
Old Jan 27, 2008 | 11:10 AM
SloChicken's Avatar
SloChicken
ORIGINAL: Roadking04
The adjustment takes minutes. I wouldn't add complexity (self-adjuster) to a simple concept.
