V & H Fuel Pak Question????
Old Jan 31, 2008 | 11:31 AM
HarleyNewbie's Avatar
HarleyNewbie
Default V & H Fuel Pak Question????
My dealer wants to charge me an hour for install on this. I'm assuming I could install this on my own. Am I correct on this? Isn't it just a plug in and punch the codes from the website type deal?
Old Jan 31, 2008 | 11:33 AM
rm4040's Avatar
rm4040
Default RE: V & H Fuel Pak Question????
Yes it is and Yes you can.
Old Jan 31, 2008 | 11:37 AM
AZCFH's Avatar
AZCFH
its real easy.just be sure to get a small phillips head screw driver for the cover and put loctite on the allen bolts that hold the spider bracket to the bike.
Old Jan 31, 2008 | 11:40 AM
SoCal_Pappy's Avatar
SoCal_Pappy
20 MIN JOB... Go for it..
DB10881's Avatar
DB10881
If you are the slightest bit mechanically inclined you can do it....
Old Jan 31, 2008 | 12:05 PM
HarleyNewbie
Thanks guys! That's what I thought. Is there any drilling involved for the spider bracket? What type/strength loctite? Anyone want to give me a play by play on the install?
Old Jan 31, 2008 | 12:09 PM
skltr's Avatar
skltr
Use the Blue Loctite, I can't tell you about the drilling
Old Jan 31, 2008 | 12:15 PM
SoCal_Pappy
NO loctite needed - Start by taking the screws out of the FuelPak (crappy litttle screws so be careful) - you'll un-plug the lead to your ECM and attached it to the FuelPak - Attach FuelPak with tie strap... And start your set-up... Once set-up uploaded re-attach screws in FuelPak and ride into the Sun light...
AZCFH's Avatar
AZCFH
no drilling required for the install. actually the best instructions come with the fuel pak they are better than any moco instructions you get with their do dads . be sure to use a quality screw driver as the screws are small and are prone to rounding out, i found out the hard way. but all in all its easy to do..
Old Jan 31, 2008 | 12:25 PM
rome304's Avatar
rome304
You will be glad you did it yourself.
[IMG]local://upfiles/22213/8A704624A7E6453085655F267206D170.jpg[/IMG]
[IMG]local://upfiles/22213/7DD8CF2BF2A747748AE23D5F7A9BFE78.jpg[/IMG]
