Need help with mounting a camera
Old Feb 8, 2008 | 09:54 PM
MustBBrent's Avatar
MustBBrent
Default RE: Need help with mounting a camera
Very cool videos maxim96.I wouldmarry that girl... and Sorry, I can't help you with the camera thing.
Old Feb 8, 2008 | 10:32 PM
MassHD's Avatar
MassHD
To get a rear view I mounted mine to the grab rail using a ram mount.
Old Feb 8, 2008 | 10:42 PM
maxum96's Avatar
maxum96
ORIGINAL: MustBBrent
Thanks for the comment. I should have clarified, back then girlfriend, now wife.
It might be a little too mushy for a HD forum, but here's how I asked her to marry me (and yes, there is video and pictures of motorcycling in it. While the camera was mounted to the handlebars I just turned it around to face us.)
http://www.youtube.com/watch?v=6L_W8b7VYqk
Old Feb 8, 2008 | 10:45 PM
johnu's Avatar
johnu
ORIGINAL: maxum96
This is a link to a couple of videos I made with my camcorder mounted on my handlebars for some shots.
http://www.youtube.com/watch?v=VW_JlG0ArR0
http://www.youtube.com/watch?v=P1F7ZIP37hE
Those videos are fantastic!!!!
I've added music to photo's using Window's movie maker for a acceptable result. Who's software are you using to mesh the videos and songs together?
Thanks,
JU
Old Feb 8, 2008 | 10:48 PM
maxum96's Avatar
maxum96
ORIGINAL: johnu
Thanks,
JU
Thanks for the comment. The first one I believe I used Window's Movie Maker, but can't remember for sure. The others were made using a software called Ulead. Far more versitile than Movie Maker.
Old Feb 8, 2008 | 11:37 PM
Rodent's Avatar
Rodent
I have the same camera I bought from a forum member. I plan on making a flat bar mount,
about 2" wide by 4" long, 1/4" thick with a 5/16" hole in the end, that will bolt up to the front brake line manifold that's mounted between the forks on the lower triple tree. I'm going to use epoxy to secure the camera quick release mounting bracket to the aluminum bar. I plan on removing the 5/16" screw and replacing it with a set screw and an acorn nut. This way, you could remove the camera mounting bracket if you wanted to, and replace the acorn nut, which holds the brake manifold securly, which would still retain clean looks.
Undo the acorn nut, mount the bar between the forks and you now have a secure camera mount which is centered to the bike, and it won't interfer in your line of sight. When you get to the campsite or motel, you can remove the camera and the mount would stay on the bike.
Old Feb 11, 2008 | 05:37 AM
captsam54's Avatar
captsam54
I bet you can find a larger adapter etc. for your crash bar size.. Probably from the same mfg as your existing mount. (or -reseller etc.)
I had a similar problem looking for a handlebar mount to fit my Pioneer Avic GPS.. BUT FOUND IT..!!
Old Feb 11, 2008 | 07:28 AM
dan boudreau's Avatar
dan boudreau
If you can get a spare rear view mirror, get some light metal, make a clamp and weld to rod of mirror works great.
Old Feb 13, 2008 | 08:56 PM
TexasUltra's Avatar
TexasUltra
Try upside down mounted to the light bar under the headlight.
PatoConcha
Jan 13, 2024 10:56 AM
bogies299
The General Motorcycle Forum
Mar 15, 2013 12:18 PM
Clint55
Aug 4, 2011 09:22 AM
deadeye
Feb 3, 2011 02:13 AM
Ugly Troll
Nov 12, 2007 07:01 PM
