Brake Light staying on
Old Jan 30, 2006 | 01:06 PM
nukeguy's Avatar
nukeguy
Default Brake Light staying on
My front brake switch is causing my brake lights to flicker on & off. Any ideas on how to fix switch on hand lever
Old Jan 30, 2006 | 01:18 PM
bountyhunter's Avatar
bountyhunter
Default RE: Brake Light staying on
Did you do some work up there, you may have broken the switch? New switch does not cost much.
Old Jan 30, 2006 | 01:38 PM
nukeguy's Avatar
nukeguy
No, haven't touched it this just started Sunday during a ride with some friends. I guessing a spring or something that returns the leverhas broke. Nice Bike
Thanks
Old Jan 30, 2006 | 02:11 PM
sestreet's Avatar
sestreet
Hi Nukeguy,
I recently took apart my hand controls to add chrome covers. The right brake switch sits in a groove in the hand control and the small tip of the switch protrudes through and is actuated by the brake lever. It may be that the switch has somehow become misaligns. I suspect though that the switch is bad.
Good Luck!
Old Jan 30, 2006 | 02:55 PM
thesmithiz's Avatar
thesmithiz
My 05 RKC did that, mostly the brake light just stayed on, it was a bad rear switch. When it first started acting up you could get it to go off by shaking the front brake lever oddly enough.
Old Jan 30, 2006 | 04:26 PM
wingt50dw's Avatar
wingt50dw
I just replaced mine...Cost was $9.95 for an aftermarket swtch and about 45 min of work. Do not cut out the entire wiring harness like the directions with the new switch say. Open the housing and find the old switch. You will have to undo a bracket (1 Screw) that holds the switches and wire then when you have a little to work with, Just clip an inch or so below the old switch and cut off the excess the same distance below the new switch. Then, just twist the wires together good and seal each with a piece of shrink tubing. No need for splicers because there is no pressure on these wires the shrink tube is more than sufficient, There is no need for pulling the wire all of the way down past the gas tank. This is how my local mechanic fixes the problem on all bikes that he services. Worked great for me and was quick and easy.
Old Jan 30, 2006 | 04:32 PM
nukeguy's Avatar
nukeguy
Thanks for everyones help sounds like a easy fix that I can do myself.
Old Jan 30, 2006 | 04:38 PM
wingt50dw's Avatar
wingt50dw
It's not that hard at all...Try getting the switch from a shop with aftermarket parts (mine came from drag specialties)...I wouldn't buy it from the dealer because it will probably cost more. Maybe from a local shop that does some work on harley's. They might even give you a short piece of shrink tube, my mechanic did. Any auto parts store will carry the shrink tubing, if you can't get it from the shop.
Old Jan 31, 2006 | 12:31 AM
dapster's Avatar
dapster
I don't believe it is the switch and here is why, I ran into the same problem when I switched out my switch caps and the reason was that there is a copper "wedge" that goes between the end of the brake lever and the housing itself that acts as a shim for the switch. It fell in the bottom of the switch housing when I loosened the housing. My buddy at the parts counter said it happens often when they are working on them and knew exactly what I was talking about when I described what I was doing and the symptoms. The replacement part was less than a dollar (phenomenal for HD I know).
DP
Old Jan 31, 2006 | 11:13 AM
wingt50dw's Avatar
wingt50dw
That shem had come out of mine before and then the switch finally got worn-out...I would surely check that first, before replacing the switch.
Harley Convert
Apr 23, 2015 07:49 AM
Northbound Southerner
Sep 3, 2012 05:20 PM
switzead
Jan 25, 2012 08:22 AM
Triple M
Sep 10, 2011 08:49 PM
jpetty
May 9, 2007 12:07 AM
