siren install HELP
Old Mar 20, 2008 | 09:23 PM
mrdeere1959's Avatar
mrdeere1959
Default siren install HELP
help i have the radio shack siren. i hooked the red wire to the brown and the black to the green. when i turn the ignition on the siren comes on. what went wrong? 08 ultra. thanks Dale in Casper
Old Mar 20, 2008 | 09:32 PM
UltraDave's Avatar
UltraDave
Default RE: siren install HELP
This is not a smart *** question but did you have your fob with you when you turned on the ignition? If not, the siren will go off after a few seconds.
Old Mar 20, 2008 | 09:43 PM
mrdeere1959
yes the fob was on the seat
Old Mar 20, 2008 | 10:35 PM
Trey Hogger's Avatar
Trey Hogger
Just did this this afternoon - not a problem here. Sure you have the black wire in the right place? Mine went in the center hole. The wire looked green with a darker stripe, the right wire (empty space) looked darker with a greenish stripe. Don't know what else it could be.
Old Mar 20, 2008 | 10:52 PM
mrdeere1959
yes black wire in middle red to brown. i looked in the service manual. the brown is fused power the middle is alarm signal from modual and the thrid is ground. dale
Old Mar 20, 2008 | 11:08 PM
acftdr's Avatar
acftdr
Hmmm... sounds like you have it wired correctly. Are you sure you're on the right connector? Left side? Do the turn signals flash as well? The siren should "chirp" as you turn the ignition on and off or arm/disarm. Can you still start the bike with the siren going off?
Old Mar 20, 2008 | 11:26 PM
Trey Hogger
Danng - any chance it's a variation of the siren but not the right one? From my receipt, #2730079.
Edit - something else to think about - it's a $6.00 part after all, maybe the siren is shorted?
frontrunner
Electrical/Lighting/Alarm
Dec 11, 2019 03:11 PM
Hurricanebm
Jan 4, 2011 07:51 PM
les63
Aug 24, 2010 11:25 AM
cwfore
Sep 6, 2009 10:45 AM
central
Mar 9, 2008 03:16 PM
