Fat Cat 2-1 Install Question?
Looking at the D&D header, it has a flat edge (fairly wide, like 1/8" or better). Just thought the SE gasket (being flat) was a better choice. That's what I used (I had both sets) - now need to check for leaks. I started her up, rode 30 minutes, let cool a bit, then retorqued.
IMO - seems like something like the SE gasket but say twice as thick would be the trick (wonder what would happen if you put two SE gaskets in?)
I noticed too how the Head pipes have a nice flat surface that seems to match up nicely tothe SE gaskets. The stock harley pipes seem to have a more rounded end.
Dont think I would put in 2 SE gaskets in the same port but if you try it I'll be anxious to know how it worked. I have both the SE & the tapered gaskets, just havent decided yet which ones I'll use ....................BG
The real objective is to get the pipe so the the muffle can is in a straight line with the two head pipes as they flow back towards the collector. "If" you can do that with the tab on top, AND not bind the motor mounts... then I suppose that would be ok too...
Stand back and look at it. You should be able to follow an "imaginary" line thru the head pipes back thru the muffler can and have that line be straight... You do not want the muffler can pointing up or down, with respect to the headpipes.
Steve, taper goes towards the pipe or towards the engine?
Yes, the Fatcat has a flat cut on the header pipe........it would make you think the S/E gasket would work, but they just don't seem to seal as well.
I'm using the Cometic gaskets that came with the top-end gasket kit..........they are a S/E style gasket, but the same material as the stock HD gaskets. I tightened them down good, and I'm having no leaks at all.
I wouldn't put 2 gaskets on top of each other...........that's going to leak like crazy.
Steve
Dont use two gaskets.
Mine slipped on very easy, so like my MoCo slip-on's I spread some of the copper stuff on the joint. Not sure how well the D&D clamp actually squeezes the joint.
