Problems with Perfomance Machine Rotors
Old Apr 26, 2008 | 07:43 PM
Waste's Avatar
Waste
Default Problems with Perfomance Machine Rotors
i'm using 2-piece Front Rotors from PM on my bike. 2-piece means the outerband is bolted on the disk carrier.
After approx. 1000 mls the bolts are loose.Does somebody have the same issue?
Old Apr 26, 2008 | 08:22 PM
Jinks's Avatar
Jinks
Default RE: Problems with Perfomance Machine Rotors
Do you mean "bolted", or riveted? Floating rotors are riveted & will loosen some. They shouldn't rattle a lot, but they should have some play in 'em.
Old Apr 26, 2008 | 08:30 PM
Waste's Avatar
Waste
there are bolted not riveted. There are 9 boltsand nut's, the nut's are self- locking, but i already lost one.
The reason is - i have the phenomenonwith medium to heavy braking, vibration and squealingis felt throughout the whole bike.I had my bike at the Dealership for the first service an they checked everything out (alignment caliper -disk -hub) all seems ok, but i still have this vibration, squealing
[/align]Any ideas?
FLHX 08, 2 piece-Performance machine rotors, stock caliper
Old Apr 26, 2008 | 08:40 PM
Jinks's Avatar
Jinks
Vibration coming from the front or rear? Do you still have the stock rotors? Are the wheels stock?
Isolate the vibration to which wheel, pull the wheel, check the balance, & put both the wheel & rotors on a truing stand & check for runout. If you still have the stock rotors put 'em back on & see if the vibration is still there.
Old Apr 26, 2008 | 10:52 PM
bigjimhp's Avatar
bigjimhp
The problem with pm rotors are they are just too thin, had several fellas switched, and problem solved
Old Apr 27, 2008 | 05:36 PM
Waste's Avatar
Waste
Jinks,
sounds logical, i like it. Thanks for your advise i'll try it. What do you think, the material combination rotor - pad, is there a negative impact?
Old Apr 27, 2008 | 05:38 PM
Waste's Avatar
Waste
by the way i#m talking about Front Wheel. I changed the stock wheels to PM.
Old Jun 3, 2008 | 08:29 PM
Waste's Avatar
Waste
Hi Jinks,
finally i got rid of my problem. Thanks again for your advise. The key to success was the changeover to LYNDALL Race Pads instead of using the stock pads.
Take care and good ride. Waste
StreetGlide515
Oct 22, 2015 07:15 PM
masterblaster
May 7, 2012 05:52 PM
soos
Oct 24, 2010 09:33 PM
EVOrider
Jan 16, 2008 03:33 PM
trucker
Mar 5, 2007 10:19 AM
