Ultra air shock pressure
Old Apr 27, 2008 | 01:13 PM
flhtupser's Avatar
flhtupser
Default Ultra air shock pressure
I normally ride 1-up 70% of the time. What pressure is good for both one and two-up riding to have a happy medium. I am 175 lbs. I have an '06 Ultra with factory shocks.
Thanks
Old Apr 27, 2008 | 01:18 PM
ridesegc04's Avatar
ridesegc04
Default RE: Ultra air shock pressure
I run 15psi in mine dont use and air compressor a small bicycle pump works fine if it has a guage built in I am 160 the little woman is 110 but I usually ride solo
soos's Avatar
soos
On my EG Classic I ride solo 0-5# two up 18-20#. I am 175# too. But I ride solo without the tourpak and two up with plus things she need to bring along.[sm=biker.gif]
Old Apr 27, 2008 | 01:22 PM
dirtdobber's Avatar
dirtdobber
That really depends on how firm you want the ride. I like a kinda soft ride with no bottoming out. I keep my shocks at 12 psi for 2 up and road trips. My wife and I together weigh 340 lbs. Invest in one of the HD pumps. Small so you can take it with you all the time and easy to use. It is not a cost but a investment.
Old Apr 27, 2008 | 07:23 PM
Theakerr's Avatar
Theakerr
Have EG Classic. Am 205lbs one up set about 15 lbs. 2 up 29 to 32lbs (say no more). I also have the HP pump but progressive also make one. Well worth it since it is a no loss system which because of the small air volume in the shocks makes setting them difficult with a conventional tire guage
Razorback Rob
Apr 26, 2014 10:21 PM
PirateRider
Feb 15, 2011 09:12 PM
joe v
Apr 19, 2008 11:43 PM
Silverearl
Jan 31, 2007 04:47 PM
GliderXXX
May 10, 2006 03:34 AM
