Hypercharger's
Old May 10, 2008 | 11:11 AM
Ross236's Avatar
Ross236
Stage II
Default Hypercharger's
They say a Hypercharger will add 7-10 HP. Does anyone have any comments about this? Or is this just for the looks? The new ones have no drilling required just a vacume hose to hook up, this should be something I could do at home. I already have a stage 1 kit installed.
Thanks guys.
Old May 10, 2008 | 11:24 AM
Solitaree1's Avatar
Solitaree1
Default RE: Hypercharger's
ORIGINAL: Ross236
Thanks guys.
From what I researched, it's all BS.
Old May 10, 2008 | 11:47 AM
frog13's Avatar
frog13
ORIGINAL: Ross236
Thanks guys.
Beware the ads that say you will gain HP from their product. If it sounds to good to be true, it probably is. Adding a Hypercharger might get you more air, but if you search here or read, an Hd engine is a big air pump. The more air that goes through, the more power, it really is as simple as that. That is why a Stage 1, more air in, the right AFR and more air out increases power. 7-10 Hp is more than 10% over stock, a huge improvement. Now, if you add the Hypercharger, a good fuel management system and a set of free flow exhaust, I would buy in that you might get near the low end of that range, bu not with the Hypercharger alone. I had one on a shovelhead I bought a while back, it's in a milk crate in the garage somewhere. Don't go for the fluff unless you just think it looks cool, do your homework and then methodically make your changes.
Old May 10, 2008 | 11:55 AM
miacycles's Avatar
miacycles
There are a lot better and less expensive air filters out there!!
Old May 10, 2008 | 12:20 PM
Roadhog02's Avatar
Roadhog02
VOO DOO, or is that DOO DOO
Old May 10, 2008 | 01:24 PM
Ross236's Avatar
Ross236
Stage II
Thanks for the thoughts and info guys, i agree there are better available, but then again they do look kind of cool
Old May 10, 2008 | 01:33 PM
MNPGRider's Avatar
MNPGRider
I watched Dr Dyno out at Sturgis work on tuning. He had a bike with a Hyper Charger on the dyno, and held a card in front of the intake. Every time he blipped the throttle the card was sprayed with gas droplets. It seems the front forward facing air scoop can't handle all the air coming in at highway speed, so it sprays back out, onto the engine and/or pants leg.
That was on a carbed bike, byw, not fuel injection.
Old May 10, 2008 | 01:56 PM
jmacdonald5's Avatar
jmacdonald5
.....ahhhh..yessss...the infamous "Hyper-Charger"....to each his own, but to me they look like a chrome toaster oven with flappin-doors....I can see havin one on a slammed street-bike....but a Bagger?....no way....like putting a hood-scoop on a Lincoln Town Car....and they don't do squat for HP over any other free-flow set up...[:'(]
Old May 10, 2008 | 02:06 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Think about it...if they worked, everybody would have one!
How many have you seen?[sm=confused06.gif]
Old May 10, 2008 | 02:13 PM
xxxflhrci's Avatar
xxxflhrci
A Hypercharger compliments a mullet rather well. It adds 7-10 "cool" factor points when judging an individual's coolness on the trailer park scale.
