glowing rear headpipe
Old May 20, 2008 | 05:20 PM
CDN. RG's Avatar
CDN. RG
Default glowing rear headpipe
I have a 07 roadglide that I have done stageone upgrade to over the winter ,I used a terry tvll for fuel management ,the bike ran hot with this device ,but it ran decent ,what bothered me the most was that I could see the rear head pipe glowing red when riding at night so I took off the tvll and replaced it with XIEDS the bike does seem to run a little cooler but I still get the glowing rear head pipe at night ,is this just the nature of the beast or should I be looking elsewhere for another fuel management device ?
Old May 20, 2008 | 05:25 PM
tinker's Avatar
tinker
Default RE: glowing rear headpipe
doesn't sound good man... running WAY too lean would be my guess.
Old May 20, 2008 | 05:26 PM
crash1292's Avatar
crash1292
man you just need to richen the chit out of it
Old May 20, 2008 | 07:59 PM
dowork08's Avatar
dowork08
my 08 did the same thing without my PCIII havent seen it do it yet....fliped me out the when i saw it i parked the bike untill the new pcIII got there
Old May 20, 2008 | 08:02 PM
electaRICK's Avatar
electaRICK
you bought the "smokers" line,,,,, its a built in cigi. lighter
Old May 21, 2008 | 12:42 AM
CDN. RG's Avatar
CDN. RG
ORIGINAL: dowork08
yeah I know what you mean it freaked me out as well ,but I have been riding it for about 2000 miles combined with both fuel management devices and there doesn't seem to be any ill effects ,the bike runs strong ,but I may have to get a pclll just for my own piece of mind.thanks for replies.
Old May 21, 2008 | 03:10 AM
poppa cooter's Avatar
poppa cooter
i use a thundermax and never seen my pipes glow. (07 ultra) the tmax has been a good unit for me definetly cooled it down and if you know some about air fuel ratios you can make your own map, or simply turn on the auto tune. do a search on here you will find alot of info on the tmax, you will see some complaints on loss of gas mileage due to the fact that the auto tune's afr is set at 13.0 but you can change it to whatever you want.
Old May 21, 2008 | 04:08 AM
marvincbr's Avatar
marvincbr
I also remember seeing the rear head pipe glowing on my 07 RG and if I remember right, it was also within the first couple thousand miles. I have just about 12k on it now and can't say I've seen that happen anymore. Just recently I also added Nightriders XIED's and it's running alot cooler now, I think the AFR is around 13.8 with them. Also now that I think about it, I didn't see the glow with the stock head pipe, it was when I first added the fulsac true duel kit. And yes, you could light a cig off of it
Old May 21, 2008 | 05:04 AM
xxxflhrci's Avatar
xxxflhrci
My buddies 100% stock '07 glows on the rear pipe, also. Sounds way too hot to me.
2010Heritage303
Jan 22, 2011 11:09 PM
62pan
Exhaust System Topics
Jun 12, 2010 08:54 PM
toolbox
Oct 2, 2008 09:45 PM
dowork08
Apr 25, 2008 06:57 PM
GlennsGlide
Oct 24, 2007 06:23 PM
