DYNO Numbers for Baggers???
In 06, the heads got a needed upgrade, but the cams started getting worse, and by 07 they were neutered badly in the name of emissions. Run a decent bolt in cam in your 09 103 bike, and you'll see a very nice bump up in power. It's relatively common to get 90+hp and 100+ ft lbs with a good cam. Look at the Woods TW-5-6, the Cycle Rama 575 and the SE204 and 255.
If all you do is a stage I, swap to a higher flow air cleaner and slip ons, yes, your ECM will adapt. Better to go to a fuel management device, though, because it will still be lean, and run hot. Add a power commander for a few hundred bucks and your bike will run better and cooler.
The o2 sensors are narrow band, meaning they will only read a small (narrow) range of A/F. If your bike is running out of this range (which it would be to lean for a stage I) then the o2 sensors don't read and won't make adjustments.
The stage I download does slightly advance the timing table, which will help decelleration popping. It will still be lean, and I wouldn't want to run a bike in that condition any more than I'd want to run a bike with the stock fuel map.
Incidentally, American Iron recently tested a bike with both slip ons and air cleaner, without the stage I download or any fuel management device whatsoever. The bike made more power, which they suggest it could not have done if it was running any leaner than stock. I think it was in AIM that I first read the theory that you didn't need to buy the download just to add stage I air cleaner and mufflers on the 07 and newer bikes.
Planning on running this 009FLHTP for a while.
Dan B.
Central Ks.
I totally disagree with AIM's theory then. HD has the bikes set up to run 12.8:1 A/F in the 100% throttle position. When AIM did a pull they were running leaner than that, (they had to be). Even if the o2's would correct they wouldn't for their dyno pull because the o2's are turned off in wide open throttle. So how could the bike they tested and made more power with not be running leaner than stock? I didn't read the article, but did tey report about the overall rideability of the bike? Or did they just say it made more power? our shop bought an Ultra Classic at auction last summer. It was a '08. We thought it was bone stock. Had stock pipes and stock air box on it. When we took delivery the bike ran like total crap. The pipes looked extremely yellow so I threw it up on the dyno to check a/f. Sure it enough, it was running way to lean. Somewhere around 15.5 - 16.0:1. When I took the a/c cover off, someone had installed a K&N filter in the stock air box. Put a stock one back in and the bike ran fine. Try it. Take your A/C cover off and go for a ride. See how it does.
