DYNO Numbers for Baggers???
Old Oct 5, 2011 | 07:00 AM
  #2791
coolerman69's Avatar
coolerman69
Originally Posted by Heatwave
Your link doesn't work but unless it shows a GPS reading I can assure that a 2006 bagger's speedo is off (light) by 4-5mph at 120. So strap a GPS on that sled and then come back with your readings.
You my friend have an answer (excuse}for anything that proves you wrong. You are the authority on EVERYTHING! I guess when my $12k EG blows by your $40k+ ego bike time after time there would be some unknown fact that would prove me the looser! I bet you ride alone A LOT!
Old Oct 5, 2011 | 08:13 AM
  #2792
mtclassic's Avatar
mtclassic
Yep...I have several degrees in fact but this debate doesn't require a college degree. My HS Senior son could have taught you alittle something from his AP Physics class that you must not have taken.
So here's your "proof of theory":
The force which will be balanced by the bike's peak horse-power (gearing setup is set for top end speed matching peak hp) is,...
F = 1/2*CdA*p*v^2 + CrW ,... where,
Cd = Coefficient of drag for the bike.
Cr = Coefficient of rolling resistance for bike.
p = Density of air,.. A = Cross sectional area of the bike,...W = Weight of the bike,...v = Velocity.
As you can see, the first term which involves air drag, increases as the square of the velocity, while the second term involving weight is independent of velocity.
Incidentally, the hp required to go a certain velocity is,... hp = F*v/550
Also since air drag is the largest factor here, the condition of that air makes a significant difference, probably more so than the weight at high speed. The air density above (p) can be estimated as follows;
p = P/(T*R) ,... where,
P = air pressure (surrounding air not tire pressure, although tire pressure is a variable on rolling resistance)
T = temperature
R = gas constant (1718 ft-lb/slug)
But the equation doesn't tell the whole story when it comes to bikes, weight and terminal velocity. The reason being that generally a heavier bike is also going to have a higher coefficient of drag because if a bike is heavier it also has a higher x-section. The x-section is generally larger due to a larger rider , larger front x-section or both. So separating out the impact of aerodynamics from weight in their impact on terminal velocity is nearly impossible without a windtunnel.
SO....
If Bike A has 100 HP and weighs 1000 lbs. - Power to weight = .1hp/lb.
If Bike B has 100hp and weighs 500 lbs. - Power to weight = .2hp/lb.
Bike 'B' will only be slightly faster than Bike 'A', (talking about terminal velocity) and this, only because of the added friction from the drag on the tires, bearings, sprockets etc. assuming bike A & B have the same Cd even with a heavier rider or bike or both.
Granted, the impact of weight is far less than the Co-efficient of drag but it is a variable. And in the bike world, higher weight almost always means a larger x-section (Cd) of both the bike and the rider.
The theoretical answer is that the heavier bike will have a slightly lower terminal velocity (1-2mph) with the same hp when you are in the 120mph range. But the practical world answer is that the terminal velocity of a 2x heavier bike could be far less than a lighter bike if the Cd of the heavier bike and rider is significantly larger than the lighter bike. In the real world case, the combination of additional weight plus higher Cd could reduce terminal velocity by 2-5 mph in the 120mph range with the same 100hp.
Are you sure you graduated High School?
proof positive that my theory is correct once again..........................guys that say they have several degrees are usually wrong when it comes to the real world. This is a real world fact regardless of what your formula say, my 2011 RGU will go ~120mph per gps and my speedo is actually spot on at 85mph per gps as I have a tts mastertune and messed around with the vss until it was spot on. I weigh ~200 in gear and driving solo I can attain 110 very quickly and then it creeps to 120 at which time the road runs out so I slow down. Now here is the real world thing....I add the weight of my wife ~150 geared up so. So figuring my bike weighs around 880 fueled up my wife only increases the weight of the bike + me by about 12-13% so in the real world adding 12-13% to the overall weight of the bike +rider will not allow said bike to get anywhere near 120mph...............and that is not based on theory or formulas that is based on fact.
Old Oct 5, 2011 | 09:50 AM
  #2793
Deuuuce's Avatar
Deuuuce
SO....
Thank you for the dissertation on aerodynamics which wasn't even the discussion nor needed whatsoever. Power to weight is for acceleration, not top speed.
And a heavier rider in full tuck may have no difference in cross area AND doesn't mean airflow past the windshield is negatively effected. Also a heavier rider may lower the bike, decreasing drag as well.
You're grasping at straws because the Cr is so minimal with a heavier rider on an identical bike that it will make virtually no difference. A 150lb rider vs. a 200lb rider will have the same top speed. 300lb rider if the same cross section won't have any appreciable difference.
Your "real world" example of 2-5mph is ridiculous because you're comparing two different bikes.
Bottom line identical bikes one rider heavier than the other is going to have a top speed differential that is insignificant for comparison purposes.
Let's use cars, an area I'm an authority on, for your ridiculous 1,000lb differentials. It's aero, gearing and hp that makes the difference, Cr is MINIMAL.
Like a C6Z and E60 M5. The Vette weighs 1,000lbs less. Yet the BMW, due to the vastly more significant factors, has a higher top end.
Or a ZR1 vs. a Bently Super Sport. Roughly the same hp? 1,500lb+ difference? Basically the same top speed.
Weight differential for the same bike is meaningless for this discussion.
Old Oct 5, 2011 | 10:52 AM
  #2794
Heatwave's Avatar
Heatwave
Member
Looks like someone doesn't know how to control their temper or emotions. Did you see me making personal attacks on someone I don't even know? I ride with multiple groups and do so for long distances. Canada, Maine, the Midwest and the NE...if you have to know. In fact, most of my riding is with a group of very experienced riders that ride long distances. I have almost 20,000 miles in less than 18 months with the vast majority of the riding with 1 of 3 different groups.
I don't bother with guys making idle threats about racing over the internet. I say it like I see it. Sometimes guys like you prefer having hot air blown up their skirt, instead of hearing the facts. Typically guys that can't handle the facts, immediately turn to personal attacks like you just did. In the end those personal attacks are irrelevant to the facts.
Sounds like someone has their own envy issues but don't expect me to come down to that level. When you show me a GPS reading at 120+ out of that stock 88 and stock heads, I'll gladly apologize for doubting you. Until then, your claim is simply another unproven internet brag without substance. Something I don't do...I'm only interested in the facts when it comes to dealing with anonymous forum posters (or even imposters).
Old Oct 5, 2011 | 10:59 AM
  #2795
Heatwave's Avatar
Heatwave
Member
So let me get this right...even when you read the real world math and the practical implications of weight (and any increase of Cd from that additional weight) you still disagree.
Ok.... I guess there are natives in New Guniea that think the world is flat too! They probably can't be convinced that we live on a globe either. Time to move on when the natives prefer to believe they live in a flat world.
Old Oct 5, 2011 | 11:05 AM
  #2796
mtclassic's Avatar
mtclassic
So let me get this right...even when you read the real world math and the practical implications of weight (and any reduction of Cd from that additional weight) you still disagree.
My theory has proven itself again. damn and I am not even high school educated. I had to drop of school in the 3rd grade to go to work to help the family out both my kids needed new shoes and the wife was pregnant again but I digress. You are way too smart and did not even read my post. If you were not so educated with your sevral degrees you would figure it out like most of the guys with common sense would do/did and got a chuckle out of it besides. P.S. go back and read the last sentence of both your posts 2782 and 2787 now go read the start of post 2794..
Old Oct 5, 2011 | 11:17 AM
  #2797
Heatwave's Avatar
Heatwave
Member
What part of the "proof of theory" that you specifically requested are you struggling with? Let me break it down more simply for you. Terminal velocity of a motorcycle is determined when the force of the engine equals 2 variables in the algorithym I shared earlier. The 1st variable is exponential in its impact and related to air resistance. The 2nd variable in the formula is linear and related to rolling resistance.
I focused on the 2nd variable since that's what you asked for. Rolling resistance is directly related to weight (among other things). A bike/rider that weighs 2 or 3x more than another bike/rider will absolutely have a meaningful, measureable and impactful difference on the terminal speed of a motorcycle. I shared with you the math and the difference when bikes of significantly different weights with the same hp are having their terminal speeds compared.
Assuming you could make the Cd of an Ultra and a Dyna the same, and then run the Dyna with 100hp and a single rider to terminal velocity, it would reach a final higher speed (by several mph) when compared with an Ultra with 100hp being ridden 2-up to its top speed. Its just simple physics and math but don't yell at me, go back and complain to your HS physics teacher for not making the principles clearer to you.
The fact that you prefer to ignore the math is something I can't address for you, just like I can't help the guy that prefers to think the world is flat. Everyone has the right to "believe" what they want, but physics and facts have nothing to do with "beliefs". Enjoy your terminal velocity riding ...whatever you might "believe" it is
Old Oct 5, 2011 | 11:25 AM
  #2798
Heatwave's Avatar
Heatwave
Member
If you have a point to make regarding the impact of weight on terminal velocity, just say it. No need for the "connect the dot game". I've never suggested that small weight differences make a significant difference in terminal speed. In fact, I clearly stated that weight is a smaller variable on terminal velocity that Cd...but it is a variable and will be meaningful when comparing bike/rider combinations that result in 2x-3x weight differences with the same power.
A 1000lb bike riding 2-up with 100hp is simply not going to reach the same terminal velocity as a 450lb bike with a single rider and a 100hp. I'm sorry but that's a simple fact of of the world we live in...or at least that I live in
Old Oct 5, 2011 | 11:45 AM
  #2799
mtclassic's Avatar
mtclassic
well in post 2794 you say you don't do personal attacks but in 2782 and 2787 you take a jab at whatever poster was disagreeing with you. And you proved my theory in two posts by lacking a certain common sense that many of the higher educated people have...in simple terms when my wife is on the back of my bike a certain thing called friction comes into play....it is her fists digging into my kidneys telling me if I go faster it is going hurt more, I am willing to bet the majority of republicans and tea partiers got this joke but the dems and libs are still scratching their heads cause they is so much smarter lol. Anyway I am just having fun so put your pocket protector way. I do believe friction via heat or other wise is going to cause some differences in top speed when it comes to much greater weights between two similar vehicles as in the real world we do not run in vacuums and we do not have unlimited time spans, perfectly flat roads etc to do top speed runs.
Old Oct 5, 2011 | 12:49 PM
  #2800
Heatwave's Avatar
Heatwave
Member
We're on the same page...my references to high school physics were minor jabs to keep this light. I wasn't interested in racing brags or putting a stick in anyone's eye over their bike or personal attacks suggesting someone's ego was bigger than someone else's.
I found the topic of the relationship between hp, weight and top end speed of our bikes to be interesting. The fact that the friction of your wife's knuckles in your sides as you reach "terminal speed" is your biggest limiting factor is something I can relate to. My bike's speed is more often than not, "terminated" by my wife long before it's terminated by aerodynamics or weight
I promise to put my pocket protector away unless its truly needed for a data duel, which is of course much safer than a terminal speed dual with our bikes!!!
