Just rinehart extreams True Duals, stage 1 intake, and PC-V with downloaded Map 69 HP 85 Torque
After Dyno Tune 75 HP 92 Torque
After 255 Cams and retuning 83 HP and 103 Torque
That's a good return for just cams. I run the same basic setup and I know what a difference you now feel from the stage 1. You are ready to ride!
2003 FLHRCI with power curve bassani duel exhaust , SS 510G cams , power cammander , SE air cleaner and dyno tune equals 83 horses at the back tire . Try for 1 horse per cubic inch . Close , but better than 68 HP stock . This HD rocks . Surprises a lot of the newer 96 CI HD's . kopper
Brand new 9 miles on odometer prior to tune (2013 RoadGlide Custom)
74 Max HP and 98 Max Torque
Screaming Eagle Pro Smart Tuner, SE Ventilator AC, ThunderHeader 2 into 1
The Dyno Sheet is still at the dealer, but I did see it and it was a pretty even line for both tq and hp across the rev range. For no motor work I'm happy with the results.
Fuel Moto 107 set on kill, 129Hp/134Tq. The results of testing over a dozen different exhaust systems, an assortment of throttle bodies, and a week of tweaks and tuning. Still some HP left in there, more to come....
Previous owner of my 2002 road king built more of a HP set up, by the looks of it. I notice my Dyno looks very different from most on here. I cant say I often feel the need for gobs of low end torque or HP, but maybe I just don't know what I'm missing? Cruising speed at 60 mph in forth gear is around 3K RPM, just a little twist of the grip and the thing feels like it has rockets under it! I do like that! What would be a good next step down in cams from my 264's to gain some low end but still keep the higher RPM bump and fun factor. I like the feeling of ever increasing power the faster the revs but would like some more low end power also, but I don't need it at 2K RPM only to petter out at 4K. What would be the next cam step down to gain a little on the bottom end but keep things fun in the top end? "103 kit with 264 cams, high comp postons, Reinheart true duals, screaming eagle A/C race kit, screaming eagle race tuner".
